net framwork 4.0 4.5 not installing
Hello, i have spent much time trying to solve this issue, but met with no success. If i try to play some games an error message comes up saying "you need to install one of the net framework v4" i try to install them and i get the error message
OS Version = 6.1.7600, SP = 0.0, Platform 2
OS Description = Windows 7 - x64 Home Premium Edition
MSI = 5.0.7600.16385
Windows version = amd64_windowsfoundation_31bf3856ad364e35_6.1.7600.16385_none_5f2ecc1aaa4ac3b2.manifest
Windows servicing = 6.1.7601.17592
CommandLine = C:\c7b78b44838c4ed5f2b7f64a14edbe7a\\Setup.exe /x86 /x64
TimeZone = Pacific Daylight Time
Initial LCID = 1033
Using Simultaneous Download and Install mechanism
Operation: Installing
Package Name = Microsoft .NET Framework 4.5 Setup
Package Version = 4.5.50709
User Experience Data Collection Policy: Disabled
Logging all the global blocks
Pre-Installation Warnings:
  1. Setup may not run properly, because the Windows Update Service is not available on this computer.
  2. Setup may not run properly, because Background Intelligent Transfer Service (BITS) is not available on this computer.
Number of applicable items: 9
Exe (C:\c7b78b44838c4ed5f2b7f64a14edbe7a\SetupUtility.exe) succeeded.
Exe Log File: dd_SetupUtility.txt
ServiceControl operation succeeded!
Exe (C:\c7b78b44838c4ed5f2b7f64a14edbe7a\Windows6.1-KB958488-v6001-x64.msu) failed with 0x424 - The specified service does not exist as an installed service. .
Final Result: Installation failed with error code: (0x00000424), "The specified service does not exist as an installed service. " (Elapsed time: 0 00:01:04).
I have uninstalled all net framework and tried reinstalling. Windows update doesnt work. i tried to start my windows update service but its not there. tried to install the standalone offline mode. checked for viruses. im out of ideas. any help would be fantastic :razz: thank you in advance
Bryan
scratch that, fixed it :p
Initial LCID = 1033
Bryan
The framework might not support hardware of your computer. Do you only need the same version of the framework ? If it is not compelled to use only the same version, try installing any other version of it.
