- Thread Author
- #1
I randomly get BSOD's, firefox crashes, random single tone beeps from the motherboard beeper and explorer errors on start up.
It is inconsistent, I may start and use my computer for hours without an error or I may get 3 blue screens in a row.
It is a new PC and has had this problem since I first installed, it is about 2 weeks old now. It is still usable but unreliable and annoying.
System Specs:
Power: Corsair TX 750
CPU: Core I5 750
Motherboard: GA-P55A-UD3 - I have updated BIOS to F6
Hardrive: 2x512GB Seagate in raid 1 (system) + another 120GB drive - all worked fine in my old system
Graphics: 1GB Gigabyte 5770 - also tested with a nvidia 8800 GTS 512 Mb that is know to work
RAM: 2 x 4G Kit DDR3 1600 G.Skill-Ripjaws
Monitor: 2 x 5ms DVI LG W2343T-PF
Operating System: Windows 7 64 bit
I am not overclocking, however I did change the CPU settings from the default that the F6 BIOS update set it to (back to the defaulst that the F3 BIOS had), the cpu currently runs at 2.66 GHz and the RAM is running at 1300.
Any Suggestions would be appreciated
System Specs:
CPU: Core I5 750
