mio
The sound disappeared after installation of windows 10. I have the latest drivers from Via date 6.0.11.800.
What to do?
If you've lost sound after installing Windows 10, you can try the following steps to troubleshoot and potentially fix the issue: 1. Check Sound Settings: - Right-click on the speaker icon in the system tray and select Playback devices. - Make sure the correct playback device is selected and set as the default. - Test the sound by playing some music or a video. 2. Update or Roll Back Drivers: - While you mentioned you have the latest drivers, it's worth rechecking if there are newer updates available on the manufacturer's website. - If the issue started after a driver update, consider rolling back to the previous driver version: - Right-click on the Windows Start button and select Device Manager. -...
If you've lost sound after installing Windows 10, you can try the following steps to troubleshoot and potentially fix the issue: 1. Check Sound Settings: - Right-click on the speaker icon in the system tray and select Playback devices. - Make sure the correct playback device is selected and set as the default. - Test the sound by playing some music or a video. 2. Update or Roll Back Drivers: - While you mentioned you have the latest drivers, it's worth rechecking if there are newer updates available on the manufacturer's website. - If the issue started after a driver update, consider rolling back to the previous driver version: - Right-click on the Windows Start button and select Device Manager. - Locate your audio device under Sound, video and game controllers, right-click, and select Properties. - Go to the Driver tab and choose Roll Back Driver if available. 3. Run Windows Troubleshooter: - Windows 10 has a built-in sound troubleshooter that can help diagnose and fix common audio problems: - Go to Settings > Update & Security > Troubleshoot > Playing Audio, and follow the on-screen instructions. 4. Check Sound Enhancements: - Right-click the speaker icon, select Playback devices, then right-click your default playback device and choose Properties. - Go to the Enhancements tab and disable all enhancements to see if that restores sound. 5. Check Windows Update: - Sometimes further updates from Windows Update can resolve sound issues. Make sure your Windows 10 is up to date. 6. Reinstall Audio Drivers: - If everything else fails, try uninstalling the audio driver completely and then reinstalling it. 7. Run System File Checker: - Open Command Prompt as an administrator and run the command: sfc /scannow. This can repair corrupted system files that may be causing sound issues. If none of these steps work, it could be a compatibility issue with your audio hardware or system configurations. In that case, you may need to contact your device manufacturer for further assistance or explore more advanced troubleshooting options.
