Windows 7 Not detecting ExpressCard SSD
pknoot
I've got Windows 7 RC 64-bit installed on a 2.53 GHz MacBook Pro (dual boot using Boot Camp) with an ExpressCard slot. I also got a FileMate SolidGO 3FMS4D48M-WR 48GB ExpressCard SSD; the drive works beautifully under OS X, but is not recognized at all by Windows 7 when it's in the ExpressCard slot. In Device Manager, the yellow caution icon appears in front of the Standard ACHI 1.0 Serial ATA Controller under IDE ATA/ATAPI controllers. The drive does not show under Disk drives or in Disk Manager. The corresponding Device Status message is: "This device cannot find enough free resources that it can use (Code 12). If you want to use this device, you will need to disable one of the other devices on this system."
The drive is recognized as SATA under Mac OS X and also works fine in Windows when plugged into a USB port instead of the ExpressCard slot (at which point it is not treated as SATA, but USB). I've tried the latest Boot Camp drivers, but that has no effect. Any suggestions?
The only thing I can think of trying that may get you somewhere is the windows update utility. It'll sometimes find software which you've hunted high and low for... Although I must stress that this is a total shot in the dark and I'm unsure if it will work..
You could also try right-clicking on the yellow mark in device manager and choose update driver. (you'll have to see if the option to automatically search your computer and the internet will turn up the correct software)
