Luqman
- Joined
- Sep 10, 2019
- Messages
- 3
- Thread Author
- #1
I transfered important data to drive d hoping that I wouldn't have to format the d drive but during the installation, I couldn't download it in the other partion and message appeared "windows cannot be installed to the disk the selected disk is of the gpt partition style". Looked for the solution online and it included cleaning the drive which I cannot because there is important data in it. Would appreciate if someone could provide a solution.
WindowsPro
- Joined
- May 19, 2017
- Messages
- 137
Luqman
- Joined
- Sep 10, 2019
- Messages
- 3
- Thread Author
- #3
I couldn't get what you just wrote. I deleted all other partitions and was left with these 2 two and partition 1 has all my data in itYour D: Drive? Is that a separate partition on "one and the same" hard-drive that is your C: drive???
WindowsPro
- Joined
- May 19, 2017
- Messages
- 137
In the bottom part of your pic, it says "Windows can not be installed to this drive" and there is a link that says "show details" that you may click on.. Is that where it says its a GPT partition?I couldn't get what you just wrote. I deleted all other partitions and was left with these 2 two and partition 1 has all my data in it
WindowsPro
- Joined
- May 19, 2017
- Messages
- 137
Luqman
- Joined
- Sep 10, 2019
- Messages
- 3
- Thread Author
- #6
Thanksnbut I was able to install the windows.While your Unallocated partition is selected, click in the "New" and create a partition using all avaliable space, then you should click on the "Format" and chose NTFS... When that is done... install windows 10 to that new partition..
Similar threads
- Article
- Replies
- 0
- Views
- 104
- Solved
- Replies
- 4
- Views
- 1K
- Solved
- Replies
- 6
- Views
- 957
- Replies
- 9
- Views
- 5K
