Windows 7 Nvidia Control Panel not opening!
Drag0ntamer
After reinstalling my drivers I can no longer open the Nvidia control panel. It shows up in processes but I cannot see it anywhere. I used Driver sweeper to do a clean install of the 270.61 64bit drivers and then used it again to install the newest beta drivers to see if that would resolve the problem. It still will not open.
I am using Windows 7 64 bit.
Hi, I saw this post and wondered if you had found a fix yet? If not, try a system restore to go back to a time before you ran Driver sweeper. (this app can sometimes cause more problems than it solves)
It was time for a reformat so I just did that and now I am up and running again.
Ok thanks for updating and great to hear your machine is sorted now..
