one note ocr
Peterr
Fantastic Member
I was successful copying a document I scanned to desktop then copied and pasted to Word -I think.
It worked before but I guess I am missing a step b/c it is not working now.
How is it done with Windows 10 -1809?
I need to edit this document.
Thank you
To copy a scanned document to your desktop and then paste it into a Word document in Windows 10 (version 1809), you can follow these steps: 1. Save the Scanned Document to Your Desktop: - Scan the document using your scanner software. - Save the scanned document to your desktop or any other folder of your choice. 2. Open Microsoft Word: - Launch Microsoft Word on your Windows 10 computer. 3. Insert the Scanned Document into Word: - Go to the location where you saved the scanned document (e.g., your desktop). - Right-click on the scanned document file and select "Copy". - In Microsoft Word, place the cursor where you want the scanned document to be inserted. - Right-click and select "Paste" to insert the scanned...
To copy a scanned document to your desktop and then paste it into a Word document in Windows 10 (version 1809), you can follow these steps: 1. Save the Scanned Document to Your Desktop: - Scan the document using your scanner software. - Save the scanned document to your desktop or any other folder of your choice. 2. Open Microsoft Word: - Launch Microsoft Word on your Windows 10 computer. 3. Insert the Scanned Document into Word: - Go to the location where you saved the scanned document (e.g., your desktop). - Right-click on the scanned document file and select "Copy". - In Microsoft Word, place the cursor where you want the scanned document to be inserted. - Right-click and select "Paste" to insert the scanned document into your Word document. 4. Edit the Scanned Document: - You can now edit the scanned document within Microsoft Word. Make changes, format the text, add images, or modify the content as needed. 5. Save Your Word Document: - After editing the scanned document, save your Word document by clicking on "File" in Word, then "Save As" to choose the file format, name, and location for saving. If you encounter issues with copying and pasting the scanned document into Word, make sure that your scanned document file format is supported by Word (e.g., PDF, JPEG, PNG) and that you have the necessary permissions to access and modify the files on your desktop. If the problem persists, you might also consider checking the file format of the scanned document and possibly converting it to a more compatible format for editing in Microsoft Word.
