To troubleshoot the issue with ODclient not starting properly on your desktop, you can follow these steps: 1. Check System Requirements: - Ensure that your system meets the minimum requirements for ODclient. Check if there are any specific requirements related to your operating system architecture (32-bit/64-bit). 2. Update ODclient: - Download the latest version from the official website to ensure you have the most recent release. Install the software and check if it resolves the issue. 3. Compatibility Mode: - Try running ODclient in compatibility mode. Right-click on the shortcut or executable, go to Properties, then the Compatibility tab, and select an earlier version of Windows the software is known to be...
