okay well i need some help and here is my issue. i bought an asus pci wireless card few months ago and installed it into my computer, no problem. soon after installation it starts to mess up. after hours of troubleshooting i return it to the store and get another one. this one works perfectly. weeks and months go by no issues at all but then all of a sudden my connection cuts out. for no reason my computer losses connection with my router, which is in the other room. the router is all good, any other wireless device works perfectly, its just my computer thats got the issue. when i do search for the wireless device it sometime takes minutes and when i do find it, it wont connect first try. ive tried reconnecting and reconnecting and most times that works, after many failed attempts, but this isnt the best solution because its just frustrating. ive put off buying a new card for awhile because most the times this issue will come and go and i keep thinking it will fix itself, but rats to that. so thats why im here asking for help. all advice is welcome.
wireless card model: ASUS PCI-G31
let me know if you want me to post any computer specs or anything that will help and ill be glad to.
thanks. Will
thanks. Will
