- Thread Author
- #1
Today was the second day where I got the "Operating System Not Found" screen, so I figured I would come this site to get some help. Just for reference I'm not very computer savi but can definitely following instructions. I have a Sony Vaio VPCEA46FM, running x64 bit Windows 7.
Little history on the situation:
1st (about a month ago)- Started the computer up one morning at work, and got the "Operating System Not Found Screen." I opened the hard drive plate to make sure the internal hard drive didn't get disconnected, I disconnected it and reconnected. So then I searched the problem on my iPhone, and went into F2 on start up and changed the start up sequence to internal hard drive 1st, instead of disk drive. Saved and restarted and it corrected the issue.
2nd- Which was today. My wife was on the computer, and walked away from the computer for a few minutes. She came back to the computer to find the computer asleep. She hit the space bar and the computer awoke to the "Operating System Not Found" Screen. She came to get me and it took me to having to go back into the F2 on start up and change the settings again. I had to make the disk drive to 3rd and external hard drive to 2nd and internal hard drive to 1st. So after that I saved and restarted and selected start windows normally, and it seemed to work fine.
So that's all the history on the situation, and would really love some help. This is my everyday laptop and I've only had it for maybe 7 months, and this stuff shouldn't be happening. So if any information is requested please reply and I will get back to you a few minutes later. Thanks,
Duff
Duff
