Hi drag sgt and Welcome to The Forum.
STOP 0x0000009F: DRIVER_POWER_STATE_FAILURE
Usual causes: Device driver.
Your latest dump file lists
pci.sys as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
AVG is known to be a cause of BSOD's on Windows 7 systems. Suggest that you uninstall it. Download the correct
Link Removed for your system
(32 or 64 bit).
If you have AVG ID protection installed, download the
AVGID Protection Remover from the above link as well
(it wouldn't hurt to download and run it anyway). Download BSOD friendly
Link Removed due to 404 Error as AVG's replacement.
Uninstall AVG through the Control Panel. Re-boot to Safe Mode and run the
AVG Removal tool
(s). Re-boot to normal mode and
install MSE. Make sure your Windows firewall is enabled! After your blue screens have been resolved, feel free to re-try AVG.
lmimirr.sys Tue Apr 10 23:32:45 2007
RaInfo.sys Fri Jan 04 18:57:14 2008 LogMeIn/RemotelyAnywhere. Has known issues with Windows 7. Uninstall this software!
Download and run
CPU-Z. Take screenshots
**/snips of the
Mainboard tab,
Memory tab and
all the
slot #'s under the
SPD tab.
Go to
Post Reply, click on the
Go Advanced button and attach the screenshots
**/snips to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
**If screenshots, please crop.
Drivers that pre-date Windows 7. Update:
QIOMem.sys Mon Jun 15 06:58:48 2009 Link Removed due to 404 Error
thpdrv.sys Mon Jun 29 03:02:56 2009
Thpevm.SYS Mon Jun 29 09:15:37 2009 Toshiba Hard Disk Protection
tos_sps64.sys Wed Jun 24 06:31:09 2009
tosrfec.sys Mon Jun 01 07:58:53 2009 Link Removed due to 404 Error
TVALZFL.sys Fri Jun 19 11:05:44 2009 Link Removed due to 404 Error
xusb21.sys Wed Apr 08 15:28:44 2009 Link Removed due to 404 Error
Drivers with Updates:
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.019.1 (Oct 2011). Also loads with
iTunes
L1C62x64.sys Fri Nov 13 09:47:36 2009 Link Removed
rtl8192se.sys Mon Apr 26 18:23:06 2010 Link Removed
Bugcheck Analysis:
* Bugcheck Analysis *
BugCheck 9F, {3, fffffa8007b83060, fffff80004aaa518, fffffa800a2b1b10}
Probably caused by : pci.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8007b83060, Physical Device Object of the stack
Arg3: fffff80004aaa518, Functional Device Object of the stack
Arg4: fffffa800a2b1b10, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE: 3
IMAGE_NAME: pci.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4ce7928f
MODULE_NAME: pci
FAULTING_MODULE: fffff88000d5c000 pci
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x9F
PROCESS_NAME: System
CURRENT_IRQL: 2
STACK_TEXT:
fffff800`04aaa4c8 fffff800`032fccd2 : 00000000`0000009f 00000000`00000003 fffffa80`07b83060 fffff800`04aaa518 : nt!KeBugCheckEx
fffff800`04aaa4d0 fffff800`0329a5fc : fffff800`04aaa600 fffff800`04aaa600 00000000`00000000 00000000`00000001 : nt! ?? ::FNODOBFM::`string'+0x34a90
fffff800`04aaa570 fffff800`0329a496 : fffffa80`0b22d010 fffffa80`0b22d010 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x6c
fffff800`04aaa5e0 fffff800`0329a37e : 0000000b`1b4e2224 fffff800`04aaac58 00000000`0004aa78 fffff800`03408188 : nt!KiProcessExpiredTimerList+0xc6
fffff800`04aaac30 fffff800`0329a167 : 00000001`bb34fac2 00000001`0004aa78 00000001`bb34fab6 00000000`00000078 : nt!KiTimerExpiration+0x1be
fffff800`04aaacd0 fffff800`0328696a : fffff800`03404e80 fffff800`03412cc0 00000000`00000001 fffff800`00000000 : nt!KiRetireDpcList+0x277
fffff800`04aaad80 00000000`00000000 : fffff800`04aab000 fffff800`04aa5000 fffff800`04aaad40 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: X64_0x9F_3_nvlddmkm_IMAGE_pci.sys
Drivers:
fffff880`0ff35000 fffff880`0ff73000 1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00f7a000 fffff880`00fd1000 ACPI ACPI.sys Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`04a45000 fffff880`04ace000 afd afd.sys Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`0ffcc000 fffff880`0ffe2000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`012d4000 fffff880`012df000 amdxata amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`077f0000 fffff880`077fb000 asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`01296000 fffff880`0129f000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0129f000 fffff880`012c9000 ataport ataport.SYS Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`06c00000 fffff880`06c2b000 AVGIDSDriver AVGIDSDriver.Sys Sun Jul 10 23:36:37 2011 (4E1A2975)
fffff880`018b1000 fffff880`018bb000 AVGIDSEH AVGIDSEH.Sys Sun Jul 10 23:36:50 2011 (4E1A2982)
fffff880`03fb7000 fffff880`03fc2000 AVGIDSFilter AVGIDSFilter.Sys Sun Jul 10 23:37:05 2011 (4E1A2991)
fffff880`04400000 fffff880`04449000 avgldx64 avgldx64.sys Fri Oct 07 04:55:41 2011 (4E8E783D)
fffff880`046b0000 fffff880`046c0000 avgmfx64 avgmfx64.sys Mon Aug 08 04:41:46 2011 (4E3F5AFA)
fffff880`018a5000 fffff880`018b1000 avgrkx64 avgrkx64.sys Tue Sep 13 05:02:34 2011 (4E6ED5DA)
fffff880`00da4000 fffff880`00db0000 BATTC BATTC.SYS Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`046fa000 fffff880`04701000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`04a00000 fffff880`04a11000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`03ee2000 fffff880`03f00000 bowser bowser.sys Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00630000 fffff960`00657000 cdd cdd.dll unavailable (00000000)
fffff880`04686000 fffff880`046b0000 cdrom cdrom.sys Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`0620f000 fffff880`062bf000 CHDRT64 CHDRT64.sys Fri Oct 16 22:56:36 2009 (4AD8EC14)
fffff880`00eba000 fffff880`00f7a000 CI CI.dll Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`0168b000 fffff880`016bb000 CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00cfe000 fffff880`00d5c000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`052c2000 fffff880`052c6500 CmBatt CmBatt.sys Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`01000000 fffff880`01072000 cng cng.sys Thu Nov 17 04:23:17 2011 (4EC48C35)
fffff880`00ff1000 fffff880`00ffa000 compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`0ffb5000 fffff880`0ffc5000 CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`07616000 fffff880`0761f000 cpuz135_x64 cpuz135_x64.sys Tue Nov 09 13:33:36 2010 (4CD94DB0)
fffff880`06200000 fffff880`0620e000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`04be2000 fffff880`04c00000 dfsc dfsc.sys Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`04bd3000 fffff880`04be2000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`0188f000 fffff880`018a5000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0554d000 fffff880`0556f000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`05575000 fffff880`05588000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`0445b000 fffff880`04663000 dump_iaStor dump_iaStor.sys Fri Oct 02 20:58:50 2009 (4AC65B7A)
fffff880`062bf000 fffff880`062cb000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`04c36000 fffff880`04d2a000 dxgkrnl dxgkrnl.sys Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04d2a000 fffff880`04d70000 dxgmms1 dxgmms1.sys Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0132b000 fffff880`0133f000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`012df000 fffff880`0132b000 fltmgr fltmgr.sys Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`015e0000 fffff880`015ea000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01855000 fffff880`0188f000 fvevol fvevol.sys Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01ace000 fffff880`01b18000 fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`052b5000 fffff880`052c2000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`037fb000 fffff800`03844000 hal hal.dll Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`04d70000 fffff880`04d94000 HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`0b693000 fffff880`0b6a6000 hiber_dumpfve hiber_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`0b48b000 fffff880`0b693000 hiber_iaStor hiber_iaStor.sys Fri Oct 02 20:58:50 2009 (4AC65B7A)
fffff880`0633f000 fffff880`06358000 HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`06358000 fffff880`06360080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`06331000 fffff880`0633f000 hidusb hidusb.sys Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`03e19000 fffff880`03ee2000 HTTP HTTP.sys Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`0184c000 fffff880`01855000 hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`05222000 fffff880`05240000 i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0108e000 fffff880`01296000 iaStor iaStor.sys Fri Oct 02 20:58:50 2009 (4AC65B7A)
fffff880`04c1c000 fffff880`04c32000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`05240000 fffff880`0524f000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`063dc000 fffff880`063ea000 kbdhid kbdhid.sys Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00b9e000 fffff800`00ba8000 kdcom kdcom.dll Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`0139d000 fffff880`013e0000 ks ks.sys Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`015b4000 fffff880`015cf000 ksecdd ksecdd.sys Thu Nov 17 03:48:13 2011 (4EC483FD)
fffff880`01660000 fffff880`0168b000 ksecpkg ksecpkg.sys Thu Nov 17 04:23:44 2011 (4EC48C50)
fffff880`0556f000 fffff880`05574200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`0520d000 fffff880`05222000 L1C62x64 L1C62x64.sys Fri Nov 13 09:47:36 2009 (4AFD2B38)
fffff880`055cc000 fffff880`055e1000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0ffc5000 fffff880`0ffcc000 lmimirr lmimirr.sys Tue Apr 10 23:32:45 2007 (461C108D)
fffff880`03fd2000 fffff880`03fe5000 LMIRfsDriver LMIRfsDriver.sys Mon Jul 14 17:26:56 2008 (487B7E50)
fffff880`05588000 fffff880`055ab000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c9b000 fffff880`00cea000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`06361000 fffff880`0636f000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`0529c000 fffff880`052ab000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`063ea000 fffff880`063f7000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00c5c000 fffff880`00c76000 mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`046c0000 fffff880`046f1000 MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`03f00000 fffff880`03f18000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`03f18000 fffff880`03f45000 mrxsmb mrxsmb.sys Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`03f45000 fffff880`03f93000 mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`03f93000 fffff880`03fb7000 mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`012c9000 fffff880`012d4000 msahci msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`0475f000 fffff880`0476a000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fda000 fffff880`00fe4000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`0133f000 fffff880`0139d000 msrpc msrpc.sys Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`04bc8000 fffff880`04bd3000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`0183a000 fffff880`0184c000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`016d3000 fffff880`017c6000 ndis ndis.sys Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`0f224000 fffff880`0f230000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`05453000 fffff880`05466000 ndisuio ndisuio.sys Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`0f230000 fffff880`0f25f000 ndiswan ndiswan.sys Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`054ce000 fffff880`054e3000 NDProxy NDProxy.SYS Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`04b13000 fffff880`04b22000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`047aa000 fffff880`047ef000 netbt netbt.sys Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01600000 fffff880`01660000 NETIO NETIO.SYS Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`0476a000 fffff880`0477b000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`04bbc000 fffff880`04bc8000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03212000 fffff800`037fb000 nt ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01411000 fffff880`015b4000 Ntfs Ntfs.sys Sat Nov 20 09:20:57 2010 (4CE792F9)
fffff880`046f1000 fffff880`046fa000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`0ff30000 fffff880`0ff35000 nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`054e3000 fffff880`05510000 nvhda64v nvhda64v.sys Thu Jul 07 17:21:14 2011 (4E15DCFA)
fffff880`0f2b9000 fffff880`0ff30000 nvlddmkm nvlddmkm.sys Sat Oct 15 07:07:55 2011 (4E99233B)
fffff880`05400000 fffff880`05453000 nwifi nwifi.sys Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`04c0b000 fffff880`04c1b700 o2mdgx64 o2mdgx64.sys Mon Nov 02 10:56:36 2009 (4AEEBAE4)
fffff880`04c00000 fffff880`04c0a780 o2sdgx64 o2sdgx64.sys Tue Aug 18 10:00:36 2009 (4A8A6DB4)
fffff880`04ad7000 fffff880`04afd000 pacer pacer.sys Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00d8f000 fffff880`00da4000 partmgr partmgr.sys Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00d5c000 fffff880`00d8f000 pci pci.sys Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00eb3000 fffff880`00eba000 pciide pciide.sys Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00c76000 fffff880`00c86000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`015cf000 fffff880`015e0000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`06cdd000 fffff880`06d83000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`063d5000 fffff880`063dbe80 pgeffect pgeffect.sys Mon Jun 22 10:00:11 2009 (4A3F481B)
fffff880`05510000 fffff880`0554d000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cea000 fffff880`00cfe000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`0ffab000 fffff880`0ffb5000 QIOMem QIOMem.sys Mon Jun 15 06:58:48 2009 (4A35E318)
fffff880`03fcb000 fffff880`03fd2000 RaInfo RaInfo.sys Fri Jan 04 18:57:14 2008 (477E818A)
fffff880`0f200000 fffff880`0f224000 rasl2tp rasl2tp.sys Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`0f25f000 fffff880`0f27a000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0f27a000 fffff880`0f29b000 raspptp raspptp.sys Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`0f29b000 fffff880`0f2b5000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`04b6b000 fffff880`04bbc000 rdbss rdbss.sys Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`04744000 fffff880`0474d000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0474d000 fffff880`04756000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`04756000 fffff880`0475f000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01800000 fffff880`0183a000 rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`06d83000 fffff880`06d8b000 regi regi.sys Mon Apr 16 16:19:10 2007 (462393EE)
fffff880`055e1000 fffff880`055f9000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`052cc000 fffff880`053f9000 rtl8192se rtl8192se.sys Mon Apr 26 18:23:06 2010 (4BD5CBFA)
fffff880`0767c000 fffff880`07685000 Sandra Sandra.sys Fri Aug 07 23:44:51 2009 (4A7CAE63)
fffff880`04b51000 fffff880`04b6b000 SCDEmu SCDEmu.SYS Wed Jun 15 09:29:27 2011 (4DF86D67)
fffff880`0ff73000 fffff880`0ffa2000 SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`06d8b000 fffff880`06d96000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01bf1000 fffff880`01bf9000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`076e1000 fffff880`07779000 srv srv.sys Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`06c2b000 fffff880`06c94000 srv2 srv2.sys Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`06d96000 fffff880`06dc7000 srvnet srvnet.sys Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`052c7000 fffff880`052c8480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`0524f000 fffff880`0529a000 SynTP SynTP.sys Fri Jul 31 01:40:03 2009 (4A723D63)
fffff880`018ca000 fffff880`01ace000 tcpip tcpip.sys Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`06dc7000 fffff880`06dd9000 tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`052ab000 fffff880`052b5000 tdcmdpst tdcmdpst.sys Thu Jul 30 09:39:35 2009 (4A715C47)
fffff880`0479d000 fffff880`047aa000 TDI TDI.SYS Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`0477b000 fffff880`0479d000 tdx tdx.sys Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`04b3d000 fffff880`04b51000 termdd termdd.sys Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff880`01be5000 fffff880`01bf1000 thpdrv thpdrv.sys Mon Jun 29 03:02:56 2009 (4A4820D0)
fffff880`01be3000 fffff880`01be4f80 Thpevm Thpevm.SYS Mon Jun 29 09:15:37 2009 (4A487829)
fffff880`01b69000 fffff880`01be3000 tos_sps64 tos_sps64.sys Wed Jun 24 06:31:09 2009 (4A41BA1D)
fffff880`0ffa2000 fffff880`0ffab000 tosrfec tosrfec.sys Mon Jun 01 07:58:53 2009 (4A237C2D)
fffff960`00410000 fffff960`0041a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`04a11000 fffff880`04a37000 tunnel tunnel.sys Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`01b64000 fffff880`01b68e00 TVALZ_O TVALZ_O.SYS Tue Jul 14 03:19:26 2009 (4A5BEB2E)
fffff880`053f9000 fffff880`05400000 TVALZFL TVALZFL.sys Fri Jun 19 11:05:44 2009 (4A3B62F8)
fffff880`062dc000 fffff880`06331000 udfs udfs.sys Sat Nov 20 09:26:11 2010 (4CE79433)
fffff880`04449000 fffff880`0445b000 umbus umbus.sys Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`0636f000 fffff880`0638c000 usbccgp usbccgp.sys Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`0529a000 fffff880`0529bf00 USBD USBD.SYS Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`04d94000 fffff880`04da5000 usbehci usbehci.sys Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`05474000 fffff880`054ce000 usbhub usbhub.sys Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`04da5000 fffff880`04dfb000 USBPORT USBPORT.SYS Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`0638c000 fffff880`063a7000 USBSTOR USBSTOR.SYS Fri Mar 11 04:37:16 2011 (4D79A6FC)
fffff880`063a7000 fffff880`063d4280 usbvideo usbvideo.sys Sat Nov 20 10:44:34 2010 (4CE7A692)
fffff880`00fe4000 fffff880`00ff1000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`04701000 fffff880`0470f000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0470f000 fffff880`04734000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00db0000 fffff880`00dc5000 volmgr volmgr.sys Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00c00000 fffff880`00c5c000 volmgrx volmgrx.sys Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01b18000 fffff880`01b64000 volsnap volsnap.sys Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`05200000 fffff880`0520d000 vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`04afd000 fffff880`04b13000 vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`04b22000 fffff880`04b3d000 wanarp wanarp.sys Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`04734000 fffff880`04744000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e00000 fffff880`00ea4000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ea4000 fffff880`00eb3000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`04ace000 fffff880`04ad7000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00090000 fffff960`003a4000 win32k win32k.sys unavailable (00000000)
fffff880`04dfb000 fffff880`04dffd00 WmBEnum WmBEnum.sys Tue Apr 27 21:10:19 2010 (4BD744AB)
fffff880`04a37000 fffff880`04a40000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00fd1000 fffff880`00fda000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`07779000 fffff880`0777b500 WmVirHid WmVirHid.sys Tue Apr 27 21:08:53 2010 (4BD74455)
fffff880`0ffe2000 fffff880`0fff3480 WmXlCore WmXlCore.sys Tue Apr 27 21:09:26 2010 (4BD74476)
fffff880`055ab000 fffff880`055cc000 WudfPf WudfPf.sys Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`062cb000 fffff880`062dbd80 xusb21 xusb21.sys Wed Apr 08 15:28:44 2009 (49DCB49C)
Unloaded modules:
fffff880`0760b000 fffff880`07616000 kerneld.x64
Checksum: 00000000
ImageSize: 0000B000
fffff880`07600000 fffff880`0760b000 kerneld.x64
Checksum: 00000000
ImageSize: 0000B000
fffff880`077ed000 fffff880`077f0000 MSKSSRV.sys
Checksum: 00000000
ImageSize: 00003000
fffff880`0777c000 fffff880`077ed000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`07685000 fffff880`0768e000 cpuz135_x64.
Checksum: 00000000
ImageSize: 00009000
fffff880`03fc2000 fffff880`03fcb000 cpuz135_x64.
Checksum: 00000000
ImageSize: 00009000
fffff880`07600000 fffff880`07671000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`07671000 fffff880`0767c000 kerneld.x64
Checksum: 00000000
ImageSize: 0000B000
Checksum: 00000000
ImageSize: 00071000
fffff880`018bb000 fffff880`018c9000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`0446b000 fffff880`04673000 dump_iaStor.
Checksum: 00000000
ImageSize: 00208000
fffff880`04673000 fffff880`04686000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
