Print screening with the mouse cursor
Cameron2000
Does anybody know about any software available to drag a cursor over an image on the internet and PrintScreen that you can then paste? avoiding having to print the screen the whole screen and cropping the image, which loses image quality.
This would be very similar to Paint where you can also drag a box over a section of an image and then move that section around or copy that section of the image.
Any suggestions would be very helpful,
Thank you.
To capture specific parts of an image or webpage without capturing the entire screen and then cropping, you can use various snipping tools or screenshot utilities. Here are some suggestions: 1. Windows Snipping Tool: - An in-built tool in Windows that allows you to capture a custom area of the screen and save it as an image. You can find it by searching in the Start menu. 2. Snipping Tool++: - A third-party tool that extends the functionality of the default Windows Snipping Tool. 3. LightShot: - A screenshot tool that allows you to select and capture specific parts of the screen quickly. It offers annotation features as well. 4. Snagit: - An advanced screen capture tool that allows you to capture scrolling...
To capture specific parts of an image or webpage without capturing the entire screen and then cropping, you can use various snipping tools or screenshot utilities. Here are some suggestions: 1. Windows Snipping Tool: - An in-built tool in Windows that allows you to capture a custom area of the screen and save it as an image. You can find it by searching in the Start menu. 2. Snipping Tool++: - A third-party tool that extends the functionality of the default Windows Snipping Tool. 3. LightShot: - A screenshot tool that allows you to select and capture specific parts of the screen quickly. It offers annotation features as well. 4. Snagit: - An advanced screen capture tool that allows you to capture scrolling webpages, specific windows, and regions on the screen. It also includes annotation tools. Using any of these tools, you can easily select the area of the image you want to capture, enhancing your workflow by avoiding unnecessary cropping and maintaining image quality.
