Windows 7 Problem after clean installing Win 7
InsaneFreakshow
Hi all, okay so yesterday I installed Win 7 on a laptop that had XP before that. XP was on C: disk, and me not being that good at reinstalling OS's I chose to make a clean install of Win 7 on disk D: Now.. if I understand correctly a clean install should've just deleted the previous OS completely right? Anyway, now Win 7 is on D and a few folders from XP (after I deleted the rest) remain on C. So the problem is that whenever I start up the laptop I always get the option to choose to start either Win 7 or XP and I don't want that. How can I remove this, I just want to have a normal start up of 7.
To each OS they are always installed on the C: drive which is just a logical partition. I would just format the drive XP is installed on then you will need to use BCDEdit from Windows 7 to delete the entry for Windows XP.
Technically you just need to delete the BCD entry and it won't prompt which OS to boot to.
BCDEdit
  • Open an elevated command prompt
  • Type bcdedit /enum
  • Locate the entry for Windows XP identifier and type
  • bcdedit /delete {identifier}
Neemobeer
Windows Forum Team
BCDEdit
InsaneFreakshow
Actually I managed to find out how to do it, but I still didn't format C: and now when I try to do it it says Win was unable to complete the format..
Neemobeer
Windows Forum Team
When you're logged into Windows 7 the OS is on the C drive and when you are logged into XP your OS is the C: drive. If you are logged into Windows 7 XP will be on the D drive.
As I stated before your currently booted operating system always shows as being on the C drive. The letter assignment is logical (a dynamic assignment)
orange juice911
Well-Known Member
How about using bootable device (USB flash drive or CD/DVD) with formating software in to format the C drive under Windows PE mode? This won't start Windows so you can delete the previous Windows XP files completely. I am not sure if the "system repair disc" of Windows 7 backup and restore utility is capable of doing this. If cannot, my suggestion is Aomei Partition Assistant. The Standard is free.
BIGBEARJEDI
Sounds like you reinstalled W7 without wiping out the partition table (thus the remaining XP boot option in the BCD menu). Reinstallation of W7 or any Windows OS is best done if the ENTIRE hard drive is formatted using the W7 install program or other utility such as DBAN. The issue here is that W7 on most OEM computers contains a utility such as ACER e-Recovery that allows you to make a set of factory DVD Recovery Discs containing your original OS (XP or W7) or a factory USB Recovery stick. Also, most OEM PC makers also install a hidden factory Recovery Partition on their C: drive which also contains this same image which contains your original Windows OS that came with the computer from the factory and contains Windows and all the utilities and other apps programs such as MS Office, AV, freeware, trialware, etc. that was on your PC when it came from the factory and can return it to OOB (Out-Of-Box) condition.
This means that hopefully, you have created those DVD/CD discs or USB stick prior to wiping out your Data Partition (XP) and replacing it with W7. If you failed to do either of those things, you can't go back to your original Windows (XP) easily. Your PC can be rebuilt manually by a professional Computer Tech for $$, or you can call up the PC maker on their support line and attempt to purchase the factory Recovery Media. This will typically cost $29-$99 US; but if your computer originally had XP on it, it can be from 9-15 years old now as of course you know XP has been obsolete for over 2 years now (April 14 2014), and most PC makers no longer keep or will sell you Recovery Media for computers that old. Sometimes you can find them on aftermarket sites such as ebay; but that's still a crapshoot to get something that works.
Be aware that if you follow OJ's recommendation, you may be destroying that built-in factory Recovery Partition that came on your hard drive. This can cause you great problems with windows licensing and activation if you don't have an actual key for your W7 (non-legit upgrade).
Check if you have Recovery Media first. If you have gone past that step already and completely formatted the C: drive at some point in this upgrade or repair process; you'll have limited options to fix it. Also, if this computer was self-built by you or a local custom-PC shop, and they or you installed XP onto this machine, and there were never Recovery Discs made or available, it's going to be quite difficult to resuscitate this computer.
Hope that neem's BCD fix works.
<<<BIGBEARJEDI>>>
