PHISHHEAD
I'm running Windows 7; 32/64 bit system.The border just changed to an awful white..I've tried all sorts of stuff; working in quite a few aspects of my control panel's appearance and personalization aspects...Listen..I know this stuff is not difficult..but I can't seem to find the answer.
In case you have not tried these "aspects".....
Adjust screen resolution:
http://www.sevenforums.com/tutorials/255-screen-resolution-display-settings.html
Reset DPI:
http://www.sevenforums.com/tutorials/443-dpi-display-size-settings-change.html
davidhk129
There is no such thing as Windows 7, 32/64 bit system. It is either 32-bit or 64-bit. Please be precise next time you post. This time, it does not matter.
If you have exhausted the personalization aspects, then, do a system restore.
Pick a date when your desktop was normal as your restore point.
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
Jimbo22
Can you post a screen shot of what you're looking at....so we here have an idea about how to suggest some fixes for you.
davidhk129
Reset DPI:
