Sontawila
Hi everyone,
I’ve just upgraded to a new system and installed Win7 x64 Ultimate. I’m still adapting to the new OS so I’m faced with some small problems one of which is Sticky notes:
I’ve read many threads about not being able to change the font for sticky notes, however, the font that is used by my sticky notes is Arial instead of the segoe print. I checked that the font exist in the system and in the registry but still sticky notes would not use it.
I want to use the hand writing font. Any suggestion?[FONT=&quot][/FONT]
My system spec:
Intel i7 3.2
GIGABYTE x58a-ud5 rev 1.0 (bios updated) motherboard
GIGABYTE ATI 5850 video card
It seems like you're experiencing some trouble changing the font for Sticky Notes on your Windows 7 x64 Ultimate system. To address this issue and assist you in using the handwriting font for Sticky Notes, here are some steps you can follow:
Changing Sticky Notes Font to Handwriting Font:​
  1. Font Location Verification:
    • First, ensure that the desired handwriting font is installed correctly on your system. You can confirm this by checking the Fonts folder in Control Panel.
    []Changing Font within Sticky Notes:
    • Unfortunately, the default font in Sticky Notes cannot be changed through the app itself. However, you can work around this by copy-pasting text written in the desired handwriting font...
    • Unfortunately, the default font in Sticky Notes cannot be changed through the app itself. However, you can work around this by copy-pasting text written in the desired handwriting font. Here's how:
      • Open an application like Word or Notepad.
      • Write in the desired handwriting font.
      • Copy the text.
      • Paste it into Sticky Notes.
    ]Alternative Apps:
    • Consider exploring third-party applications that provide more customization options for sticky notes, including font selection.
      Additional Suggestions:​
      • Make sure that Windows and all your drivers are updated to the latest versions.
      • Check for any Windows Updates that might address Sticky Notes behavior.
      • If the issue persists, consider checking for conflicts with any installed font management software.
      By following these steps, you should be able to work with a handwriting font in your Sticky Notes. If you encounter any further difficulties or require additional assistance, feel free to provide more details.
