Windows 7 problems burning dvd's
danwade23
I am trying to burn a home movie onto a disc using the windows burning tool.
However even though the file is only 700mb and the disc is 4.8gb it says i dont have enough space on the disc. Tried with several discs.
Any solution to this?
When you encounter issues where the Windows burning tool indicates that there isn't enough space on the disc even though your file size is significantly smaller than the disc capacity, there could be a few reasons behind this. Here are some steps to troubleshoot and potentially resolve this issue:
Steps to Resolve Disc Burning Space Issue:​
  1. Check Disc Formatting:
    • Ensure that the disc you are using is blank and writable (e.g., DVD-R, DVD+R) and has been formatted correctly. If it is a rewritable disc (DVD-RW, DVD+RW), try erasing the contents before burning the movie.
    []File System Compatibility:
    • Make sure that the disc uses a compatible file system for burning. For DVDs, it's generally...
    • Make sure that the disc uses a compatible file system for burning. For DVDs, it's generally recommended to use the UDF (Universal Disk Format) file system for burning larger files. You can change the file system during the burning process or using third-party software.
    ]Burn Speed and Compatibility:
    • Sometimes burning at lower speeds, such as 4x, can help with compatibility and reduce errors during the burning process. Try burning the disc at a lower speed if you encounter issues.
    []Check File Integrity:
    • Verify that the file you are trying to burn is not corrupted. You can try playing the movie file on your computer to ensure it is in good condition before burning it to a disc.
    ]Alternative Burning Tools:
    • If the Windows burning tool continues to show errors, consider using third-party disc burning software like ImgBurn, CDBurnerXP, or Nero Burning ROM. These tools might offer more customization options and better compatibility.
    []Update Device Drivers:
    • Ensure that your optical drive's drivers are up to date. Outdated drivers can sometimes cause issues with disc burning operations.
    ]Run Hardware Troubleshooter:
    • You can run the Hardware and Devices troubleshooter to diagnose and potentially fix issues related to your optical drive or disc burning problems.
      Additional Tips:​
      • Data Overhead: Keep in mind that even though your file is 700MB, there might be additional data overhead required for burning the file to the disc.
      • Try Different Disc Brands: In some cases, specific disc brands may work better with certain optical drives. Experimenting with different disc brands might help in resolving the issue.
      Try these steps to troubleshoot the space issue when burning your home movie onto a disc using the Windows burning tool. If the problem persists, switching to a different burning tool or making adjustments to the burning settings might help resolve the issue.
