Windows 7 Problems with manifest or policy file.
The Balar
Recently my computer has been freezing up frequently. I have made sure it's not a heat issue or a driver issue. I used MTB to determine what the source of the problem was. I found out that the error,
Description: Activation context generation failed for "WLMFDS,processorArchitecture="AMD64",type="win32",version="1.0.0.1"1".Error in manifest or policy file "WLMFDS,processorArchitecture="AMD64",type="win32",version="1.0.0.1"2" on line WLMFDS,processorArchitecture="AMD64",type="win32",version="1.0.0.1"3.
Component identity found in manifest does not match the identity of the component requested.
Reference is WLMFDS,processorArchitecture="AMD64",type="win32",version="1.0.0.1".
Definition is WLMFDS,processorArchitecture="x86",type="win32",version="1.0.0.1".
Please use sxstrace.exe for detailed diagnosis.
,pops up most frequently. Furthermore it pops up at the exact time my computer freezes.
How do I go about fixing this problem?
(attached most recent MTB log)
is your system fully updated with both drivers and Bios?
What are your temperatures at rest and at full load?
Have you scanned for malware?
