* Bugcheck Analysis *
BugCheck 27, {baad0073, ffffd000238fcce8, ffffd000238fc500, fffff800fa4daf68}
Probably caused by : ntoskrnl.wrong.symbols.exe ( nt_wrong_symbols!59029C7C850000 )
Followup: MachineOwner
all the dump files appear the same although complain of incorrect file symbols. This probably just relates to ntoskrnl.exe as there are a couple of versions.
In any case the dumps relate to a sub system driver 'Rdbss' and it may have become corrupted or another driver is causing it to crash.
RDBSS, amongst other things deals with SMB network operations ((
SMB protocol) provides a method for client applications in a computer to read and write to files on and to request services from server programs in a computer network. )
File scans to clear possible corruption.
Right click on the Start menu icon and from the revealed list choose 'admin command prompt'. Type:
sfc /scannow
press enter and await results
As the bsod is looking network related try first removing your security AV suite 'Sophos'. You can always re-install later but for now please just use the on board Defender.
e1d65x64.sys Thu Aug 13 10:14:29 2015: Intel Pro/1000 Network Adapter driver. A later version can be found on your systems support page:
Support for Latitude E7470 | Dell US iaStorAV.sys Thu Feb 19 12:08:39 2015: Intel Rapid Storage Technology SATA RAID Controller driver please update:
Intel Rapid Storage Technology Driver and Management Console Driver Details | Dell US ImperoInjDrv64.sys Sun Oct 26 17:54:13 2014: Impero DLL Injection Driver? Possible suspect please remove.
See how you go after making the above changes. Please post any new dump files after updating the above.
