Windows 7 reghakr please help with blue screen
JonDavidShaw
Reghakr,
You seem to know what you are doing, and i have read many post that you have replied to people about having blue screen problems.
I have listed my system config under my name so that is already ready for you. I seem to be having a frequent problem while using firefox and on the web, downloading of any sort, and when i play any game online. I read one post that someone was having a problem with their network driver, so i when to gigabyte.us and downloaded the most frequest W7 64bit driver for my motherboard, but it did not fix the problem. I tried using the one that came with the disk, but it is only made for Vista so i was not able to use it.
Sorry forgot to add that this is a clean install, not a upgrade. I was using Win XP SP3 before i installed this.
I also checked my Device Manager and there are no issues with any hardware.
Any and all help will be greatly appreciated!
Thanks again
Jon
Download this freeware utyikty to bnetter diagnose the bkue sceen erro:Automatically scans your current minidump folder and displays the list of all crash dumps, including crash dump date/time and crash detail
BlueScreenView v1.15
BlueScreenView Features
  • Allows you to view a blue screen which is very similar to the one that Windows displayed during the crash.
  • BlueScreenView enumerates the memory addresses inside the stack of the crash, and find all drivers/modules that might be involved in the crash.
  • BlueScreenView also allows you to work with another instance of Windows, simply by choosing the right minidump folder (In Advanced Options).
  • BlueScreenView automatically locate the drivers appeared in the...
  • BlueScreenView automatically locate the drivers appeared in the crash dump, and extract their version resource information, including product name, file version, company, and file description.
i have already downloaded this program, and when i look at it, and research the errors i am getting most of them refer to memory problems.
