Windows 8 Rights Protected Folder Explorer
A new and interesting release from Microsoft:
Rights Protected Folder Explorer is a Windows based application that allows you to work with Rights Protected Folders. A Rights Protected Folder is similar to a file folder in that it contains files and folders. However, a Rights Protected Folder controls access to the files that it contains, no matter where the Rights Protected Folder is located. By using Rights Protected Folder Explorer, you can securely store or send files to authorized users and control which users will be able to access those files while they are in the Rights Protected Folder. Rights Protected Folder Explorer works with Active Directory Rights Management Services (AD RMS) in your organization’s network to control access to Rights Protected Folders. When you create a new Rights Protected Folder, Rights Protected Folder Explorer allows you to select a policy to protect the contents of the Rights Protected Folder, or you can create a custom policy. The policies that you can select from are set by your network’s AD RMS administrators and are the same policies you can use in such applications as Microsoft Word or Microsoft Outlook to protect documents and messages. Rights Protected Folder Explorer supports both UI based support (for end-user interaction) and command line support for automated solutions.
Download:
The Rights Protected Folder Explorer from Microsoft is a Windows application that facilitates working with Rights Protected Folders. These folders function similarly to regular file folders but provide enhanced control over the access to the files they contain, regardless of their location. Here are some key points about this tool: - Functionality: The Rights Protected Folder Explorer allows users to securely store or share files with authorized individuals while controlling who can access these files within the Rights Protected Folder. - Integration with AD RMS: The tool seamlessly integrates with Active Directory Rights Management Services (AD RMS) in your organization's network to manage access to Rights Protected Folders. - Policy Implementation: Users can choose from predefined policies set by the AD RMS administrators to protect the contents of the Rights Protected Folders or create custom policies according to their needs. - Compatibility: The policies available in Rights Protected Folder Explorer align with those used in applications like Microsoft Word and Outlook for safeguarding documents and messages. - User Interaction: Rights Protected Folder Explorer offers both a user-friendly graphical interface for manual operations and command-line support for implementing automated solutions. This tool enhances security by providing a robust mechanism to control access to sensitive files and folders. Users can benefit from the advanced security features of Rights Protected Folders while collaborating and sharing information within a secure environment.
