running .bat each time computer starts
i would like to if its possible on windows 7 to run a bat each time computer starts from HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run for example of from startup
or its just not possible because of the uac ?
i dont want to use task scheduler
Mike
Windows Forum Admin
In Windows 7 Professional and above go to Start -> Search -> gpedit.msc
Navigate to Computer Configuration -> Windows Settings -> Scripts (Startup/Shutdown)
From here, you can use GPO scripts to accomplish what you are getting at. However, Task Scheduler would be a lot easier.
Use this important resource: Scripting for Group Policy
