Screen Keeps Going Black Then I have To Restart
Greetings!
I have a Problem With my Computer, When I'm doing my work my computer screen keep going to a black screen. I use a ViewSonic Screen.
Please Help
techmonkey74
Lifetime Premium Supporter
Is this when the computer sits idle? Is the monitor actually turning off?
When i move the mouse and let it stay a bit it goes to the black screen.
techmonkey74
Are you power settings set to turn the monitor off? Do you have another computer you can hook the monitor up to for testing?
My friend is using it right now i'm using an old computer, I'll check it later.
Yes but on my Gateway had the same thing so i don't know about that but I have two moniters.
techmonkey74
If it's not your power settings and the same this happened with this monitor on your Gateway, I would say it's the monitor and with the price of most monitors being fairly cheap it would not be work repairing
#7
I guess View Sonic is not worth using for.
techmonkey74
#8
I think we need to move this to a different forum since I believe this is a discussion only forum.
#9
Yup!!!!!!!
