Windows 10 screen saver wont turn on
rkfjr
win 10 no changes done to pc all of a sudden tm pictures screen savor will not start it has been working ok till now there has been no changes to my ps. I go to settings peroneal settings themes and see the px in the prevue and the time to start is 8 min but it wont start.
Then there isn't anything in a blocking state. Can we see your current power config.
You can run this and upload the txt file created on your desktop.
powercfg /Q >> %USERPROFILE%\Desktop\power.txt
Neemobeer
Windows Forum Team
You could have a process, driver or service preventing sleep. Open an elevated command prompt and type powercfg /REQUESTOVERRIDE any thing listed in will prevent the screen saver from firing.
rkfjr
copyed and pasted your ans and it says inproper
copied and pasted this command and it says Improper parameters
rkfjr
Subject: Re: screen saver wont turn on - New reply to watched thread
3 listings {service} {process} {driver}
Neemobeer
Windows Forum Team
