SFTP Mapped To Network Drive
Will2238
The other day I created an FTP server for file sharing, I map it to a network drive and Windows warns me that FTP is not secure. I look into it and decide to upgrade to SFTP instead, then I find out windows cannot map SFTP natively. So, my question is what is the best solution to map the SFTP server to a a drive letter? I have already tried Swish and it does not map to a drive letter. Also, I created a feature request in the Windows Feedback Hub that you can upvote to hopefully have it added soon, just open the Windows Feedback Hub and search SFTP in All Categories.
If you are still stuck and need other 3rd party option suggestions, I can recommend WebDrive. I have used it for years and while it isn't free, I found the cost reasonable when I purchased and I have never had any issues with it.
Did you try the other options mentioned? Curious to know what you think, as I am always looking to try new things!
Josephur
Windows Forum Admin
I doubt Windows will add SFTP to mapped drive support anytime soon unfortunately.
There's a few third part options however:
ExpanDrive
NetDrive
win-sshfs
I don't know which is "the best", try them all and let us know :)
Will2238
ExpanDrive
NetDrive
win-sshfs
Thanks for the reply and software to look at. I hope other people want this too and upvote my feedback so I won't need to use a third party solution.
BeNlW21
