The Siemens MS/TP Point Pickup Module, a specialized device widely deployed across sectors such as commercial facilities, government infrastructure, healthcare, information technology, and transportation, has recently been found vulnerable to a newly identified security flaw. This vulnerability, catalogued as CVE-2025-24510, underscores the persistent risks embedded in operational technology (OT) — and raises important questions about both the pace and politics of industrial device patching. In this feature, we drill into the specifics of this Siemens vulnerability, contextualize it within the broader industrial control system (ICS) security landscape, and examine what it means for Windows-centric OT professionals and system administrators tasked with safeguarding critical infrastructure.
A high-tech control room with multiple digital screens and advanced equipment in a futuristic lab.
Overview of the Siemens MS/TP Point Pickup Module Vulnerability​
Siemens’ MS/TP Point Pickup Module is a component integral to BACnet-based building automation networks, where it acts as a relay, collecting and issuing control signals for HVAC systems and other building management technologies. On May 15, 2025, an advisory jointly issued by CISA and Siemens ProductCERT publicly confirmed a vulnerability stemming from improper input validation (CWE-20) in the module’s handling of BACnet MS/TP messages. This fault exists in all versions of the device, and as of this writing, Siemens has stated that no firmware fix is planned — a notable stance that leaves many operators reliant solely on compensatory controls.
Technical Details: What Exactly Is at Risk?​
The crux of CVE-2025-24510 is the device's failure to robustly validate specific BACnet MS/TP messages received from the local network. An attacker with access to the same physical segment of a BACnet MS/TP network could exploit this by sending specially-crafted packets. The result: the module enters a denial of service (DoS) state that requires a manual power cycle for recovery.
Key details include:
  • CVSS v3.1 Base Score: 6.5 (High Availability impact; details: AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H)
  • CVSS v4.0 Base Score: 7.1 (Heightened in the latest scoring model, which better captures OT exposures)
  • Attack Vector: Adjacent network (attacker must be on the same BACnet segment)
  • Complexity: Low, meaning exploitation does not require advanced knowledge or tools
This vulnerability is notable for:
  • Its low attack complexity — increasing risk in environments where network segmentation is weak or where trusted insiders may act maliciously.
  • The lack of a software or firmware remediation path, meaning legacy hardware continues to accrue risk over time.
  • Applicability to “all versions” of the module, raising the likelihood that even recent deployments are impacted.
What Makes This Vulnerability Critical?​
Though the vulnerability is locally exploitable and does not directly allow for data exfiltration or code execution, the implications for affected organizations should not be underestimated. In building automation and ICS networks, the availability of field devices is paramount. A well-timed denial of service attack could disrupt building climate control, lighting, access control, or energy management, with implications that cascade into operations, safety, and compliance.
The sectors at risk are varied and include:
  • Commercial Facilities: Office buildings, retail, and data centers, where environmental conditions are business-critical.
  • Government Facilities: Where interference could impede security or public services.
  • Healthcare and Public Health: Where HVAC failures can affect life safety systems and patient care environments.
  • Transportation Systems: Where building automation regulates critical infrastructure like stations or tunnels.
The broad, global installation base and the module’s foundational role in BACnet MS/TP topologies multiply the stakes.
Windows and ICS: Converging Risks​
For Windows professionals, the Siemens incident is a vivid reminder that ICS security often revolves around legacy hardware and opaque embedded systems — not just the Windows operating systems that manage or visualize them. Yet, many MS/TP Point Pickup Modules are deployed in proximity to PC-based building management systems, often themselves running on Windows Server or Windows 10/11 platforms. This proximity means vulnerabilities on the OT/ICS side can sometimes provide indirect avenues for attackers to impact corporate IT.
The challenge: Windows system administrators and IT security managers may be tasked with the defense of BACnet networks even when the devices themselves are “black boxes” from a patching and hardening perspective.
The Shared Responsibility Model: IT Meets OT​
Siemens recommends users follow its operational security guidelines, which include network hardening, segmentation, and exposure minimization. CISA’s parallel recommendations echo the familiar defense-in-depth doctrine, encouraging:
  • Placement of critical devices behind dedicated firewalls
  • Segmentation of ICS from corporate IT
  • Prohibition of direct Internet exposure for OT devices
  • Use of VPNs for remote access, with the caveat that VPNs themselves must be patched and well-managed
Both agencies underscore the need for “proper impact analysis and risk assessment” — a reminder that even seemingly niche OT vulnerabilities must be considered in broader business continuity and incident response planning.
Analyzing Siemens’ “No-Fix” Policy​
It is rare, but not unprecedented, for an industrial vendor of Siemens’ size to declare “no fix is planned” for an actively exploitable vulnerability discovered in a widely deployed product. Several possible reasons could explain this position:
  • Hardware Constraints: The vulnerable device may lack spare memory or CPU headroom for more robust input validation routines.
  • Business Lifecycle: The module may be near or past end-of-life (EOL), with Siemens focusing resources on newer platform generations.
  • Market Calculation: Offering only compensatory mitigations might reflect the vendor’s risk matrix, balancing cost, liability, and customer expectations.
The ultimate effect is that risk transfers almost entirely to asset owners and system integrators. While compensatory controls such as network segmentation certainly reduce the threat surface, they also demand sustained vigilance and architectural discipline — qualities that may not always be present in multi-decade deployments.
Industry analysts have noted that this situation highlights a recurring tension in ICS: the mismatch between the expected service life of OT hardware (often 15-25 years) and the typical patch support lifecycle (usually much shorter). This tension frequently leads to security debt accruing in facilities where upgrading or physically replacing devices represents significant capital outlay or operational downtime.
Real-World Risk Scenarios​
To sharpen appreciation for the implications of CVE-2025-24510, consider a few practical scenarios:
Scenario 1: Insider Threat in Facility Operations​
An HVAC technician or building controls contractor, whether malicious or simply careless, could disrupt operations by sending crafted BACnet MS/TP packets using low-cost hardware tools. The resulting denial of service could affect temperature, airflow, or other critical environmental parameters for hours until maintenance staff manually reset devices.
Scenario 2: Network Sprawl and Shadow IT​
In organizations where BACnet networks have grown without centralized oversight, “flat” architectures abound. A compromised Windows device attached to a BACnet segment could serve as a launch pad for message injection attacks, either as part of ransomware campaigns or simple vandalism.
Scenario 3: Sophisticated Threat Actor Targeting Critical Infrastructure​
Nation-state actors or advanced persistent threats (APTs) have increasingly focused on the intersection of IT and OT. While there is currently “no known public exploitation” of this vulnerability, security researchers have repeatedly shown that ICS vulnerabilities disclosed in “unexploited” status can become active targets within weeks or months.
Defensive Strategies: What Can (and Should) Operators Do?​
With Siemens declining to issue a patch, organizations are compelled to rely on architectural and procedural countermeasures. Below are concrete steps asset owners can take, validated by consensus best practice guidance from both Siemens and CISA.
1. Implement Robust Network Segmentation​
  • Ensure BACnet MS/TP networks are logically and physically separated from business IT networks.
  • Use firewalls or data diodes to strictly limit cross-network communications.
  • Limit BACnet routings to only those explicitly required for business or operational necessity.
2. Harden Device Access​
  • Disable or restrict unused physical ports (USB, serial) that could be exploited for message injection.
  • Apply strict access controls for all endpoints with BACnet MS/TP connectivity.
  • Monitor for physical access anomalies, especially after-hours.
3. Monitor Traffic and Anomalies​
  • Utilize Intrusion Detection Systems (IDS) designed for industrial protocols (e.g., BACnet-aware monitoring).
  • Set up active alerting for network storms or unexpected denial-of-service symptoms on building management networks.
4. Develop and Test Incident Response Playbooks​
  • Train operational staff on recognizing and responding to denial of service symptoms affecting building management systems.
  • Pre-stage and periodically test recovery procedures, such as manual power cycles for affected devices.
  • Maintain spares for rapid replacement or reset of vulnerable modules.
5. Coordinate with IT and Third-Party Partners​
  • Include facility management, IT, and security operations in tabletop exercises and vulnerability assessments.
  • Demand transparency from service providers about their patch and response policies for building automation hardware.
The Regulatory and Compliance Angle​
Governments and industry regulators are sharpening their focus on the security of operational technology, especially where critical infrastructure is concerned. Although no exploit of CVE-2025-24510 has been publicly reported, disclosure alone may trigger heightened audit scrutiny or drive risk ratings in insurance and compliance frameworks.
Organizations bound by frameworks such as NIST SP 800-82 (Guide to Industrial Control Systems Security), ISO/IEC 62443, or local critical infrastructure laws are expected to demonstrate not only awareness of vulnerabilities but also active, documented management. In this light, asset owners who “do nothing” in response to Siemens’ advisory could face downstream repercussions in both regulatory audits and business contracts.
Comparing with Historic ICS Vulnerabilities​
CVE-2025-24510 belongs to a long lineage of ICS vulnerabilities where the root cause is insufficient input validation. From the infamous Stuxnet-related flaws in Siemens’ S7-300/400 PLCs, to BACnet fuzzing weaknesses catalogued in CVE-2019-13537, the pattern is clear: protocol traffic not expected by device designers decades ago can often trigger unintended, sometimes catastrophic, behaviors.
In each major instance, mitigations almost universally involve steps external to the device — segmentation, monitoring, and governance controls — rather than the kind of inside-the-box update familiar to Windows admins. This reflects both the practical realities of industrial product engineering and the slow pace of change in OT environments.
The Role of Windows in OT Security Posture​
Windows-based building and automation management workstations remain a key line of defense (or weakness) for industrial networks. Many BACnet networks rely on server software, visualization panels, and gateway devices running on Windows Server, Windows 10, or newer platforms. These systems, if compromised, can serve as pivot points for adversaries seeking to inject malicious traffic into normally isolated fieldbus networks like MS/TP.
Effective security in such hybrid environments hinges on:
  • Robust patching of all Windows hosts on building management or integration networks.
  • Principle of least privilege, restricting device and admin credentials.
  • Segregation of duties between IT, building maintenance, and OT support teams.
  • Routine vulnerability scanning, recognizing the limits of traditional IT scanners in parsing proprietary industrial protocols.
A lack of integration or awareness between Windows-centric IT teams and their OT counterparts continues to present an “organizational vulnerability” — one not addressable by technical mitigations alone.
Cautionary Notes and Unanswered Questions​
While both Siemens and CISA report “no known public exploitation” targeting MS/TP Point Pickup Modules at this time, such assessments are always provisional. The rapid weaponization of recent ICS vulnerabilities (notably those disclosed and patched in more mature platforms like Windows and Linux) suggests adversaries are increasingly adept at translating “white paper” flaws into operational tools.
Further uncertainties include:
  • Legacy Support Window: Will Siemens ultimately issue a patch or phase-out replacement if the threat environment shifts?
  • Coordinated Disclosure: Could third-party researchers discover chained or adjacent vulnerabilities, magnifying risk?
  • Long-Term Monitoring: Will asset owners invest in the monitoring and analytics needed to detect attempted exploitation in the coming years?
Organizations are thus urged to treat Siemens' mitigations as a minimum baseline — not an endpoint.
Looking Forward: Toward Sustainable ICS Security​
The Siemens MS/TP Point Pickup Module advisory is more than a routine technical notice; it is a case study in the stubborn realities of ICS vulnerability management. For Windows-based IT and OT professionals, several core lessons emerge:
  • Proactive network and asset management is indispensable. Where patching isn’t possible, architecture and operations form the bulwark of defense.
  • IT and OT silos are a liability. Windows-centric and device-centric teams must collaborate, blending expertise in software security and physical infrastructure.
  • Communicate risk to stakeholders, from facility managers to C-suite leaders, using real-world scenarios that frame ICS vulnerabilities not as IT arcana, but as operational concerns with business impact.
Organizations that succeed will do so not by eliminating all vulnerabilities, but by cultivating a culture — and infrastructure — of resilience, visibility, and rapid response.
The exposure of the Siemens MS/TP Point Pickup Module to denial of service attacks underscores enduring truths about ICS environments. Patchability is not guaranteed. Vendor lifecycles often mismatch true asset lifetimes. And as OT environments embrace more cloud, automation, and IT convergence, old “air gap” assumptions become obsolete. As vulnerabilities with no planned vendor fix become more common, organizations must double down on lateral defenses — from segmentation and device monitoring to coordinated incident response spanning both Windows and embedded device landscapes.
While CVE-2025-24510 may not currently be known as a vector for major attacks, the evolving ICS threat landscape makes vigilance and preparation imperative. The Siemens incident serves as a timely, concrete prompt for building more robust, adaptive, and collaborative approaches to cyber-physical security — across Windows, ICS, and every interstitial layer between.
Source: CISA Siemens MS/TP Point Pickup Module | CISA
