Exploring a mysterious, post-apocalyptic Earth as EVE in Stellar Blade left a lasting impression on PlayStation 5 owners in 2024. Now, with the upcoming PC release, a broader community of gamers stands ready to experience Shift Up’s stylish, narrative-driven action adventure. But before jumping into EVE’s high-stakes battles, the question arises: is your PC up to the task? With requirements ranging from manageable to downright demanding, Stellar Blade’s PC port provides options across a variety of rigs—though certain quirks and risks are well worth considering.
A futuristic armored warrior stands with crossed swords in a ruined cityscape at dusk.
The Jump from Console to PC: Expectations and Realities​
In recent years, Sony has shifted more of its previously exclusive PlayStation hits to the Windows ecosystem. From God of War and Horizon Zero Dawn to Marvel’s Spider-Man, the trend is clear: triple-A action games are no longer just for consoles. Stellar Blade’s arrival on PC continues this strategy, promising not only parity with the PS5 but possible enhancements, including unlocked frame rates and higher resolutions.
Yet, moving from fixed hardware like the PlayStation 5 to the wildly variable world of PC is never straightforward. Developers must account for a vast range of CPUs, GPUs, and memory configurations. Performance hiccups, compatibility quirks, and optimization challenges are par for the course. With Stellar Blade’s Steam release set for June 11, 2025, Shift Up has released detailed system requirements revealing both strengths of the PC port—and its most prominent potential pitfalls.
Hardware Requirements: A Four-Tier Breakdown​
Stellar Blade’s PC requirements are split across four tiers: Minimum, Recommended, High, and Very High. Each tier suggests target resolutions and graphics quality levels, giving users clarity over the experience to expect—if their system meets the specs.
Minimum Requirements: Entry-Level Playability​
Running at 1080p and aiming for 60 frames per second on Low settings, the minimum requirements are accessible—but not exactly modest by 2020s standards. Here’s what you’ll need:
  • CPU: Intel Core i5-7600K or AMD Ryzen 5 1600X
  • GPU: NVIDIA GeForce GTX 1060 6GB or AMD Radeon RX 580 8GB
  • RAM: 16 GB
  • OS: Windows 10 64-bit or Windows 11 64-bit
  • Storage: 75 GB HDD (SSD strongly recommended)
A surprising element is the absolute 16 GB RAM baseline. While this has slowly become the new norm, many older action games tolerate 8 GB with reduced performance; Stellar Blade, however, joins a growing list of new-gen titles dropping support for less memory. The GPU requirements are in line with mid-range cards released back in the late 2010s. While a mechanical hard drive is technically allowed, Shift Up’s strong recommendation of an SSD suggests that loading times and streaming issues could otherwise be significant.
Recommended Requirements: Aiming Higher at 1440p​
To enjoy stellar 1440p visuals at 60 FPS on Medium settings, players need more modern hardware:
  • CPU: Intel Core i5-8400 or AMD Ryzen 5 3600X
  • GPU: NVIDIA GeForce RTX 2060 SUPER or AMD Radeon RX 5700 XT
  • RAM: 16 GB
  • OS: Windows 10/11 64-bit
  • Storage: 75 GB SSD
Notably, the jump from minimum to recommended spec is mostly in the GPU department. The RTX 2060 SUPER, released in 2019, continues to be a reliable standard for new mid-range PC ports. CPUs from the mid-to-late 2010s are still supported, although it’s clear that a quad-core or higher processor is required.
High Requirements: Cranking the Visuals​
"High" requirements stick to 1440p at 60 FPS but add an expectation for High graphics settings. Hardware recommendations increase, but not drastically:
  • GPU: NVIDIA GeForce RTX 2070 SUPER or AMD Radeon RX 6700 XT
  • RAM: 16 GB
Again, the CPU requirements hold steady, signaling that much of Stellar Blade’s workload is focused on the GPU. The move to RTX 2070 SUPER or its AMD equivalent marks the clearest line between ‘good’ and ‘great’ visuals. Both cards are well within the reach of PC gaming enthusiasts, though their prices have fluctuated in the wake of supply constraints and new-gen releases.
Very High Requirements: 4K, 60 FPS, Maximum Details​
The ultimate "Very High" tier is where the demands ramp up, as Stellar Blade promises 4K resolution at 60 FPS with the eye-candy turned to max.
  • GPU: NVIDIA GeForce RTX 3080 or AMD Radeon RX 7900 XT
  • RAM: 16 GB
While the CPU remains curiously unchanged—even at 4K—the GPU requirement jumps by a significant margin. Both the RTX 3080 and RX 7900 XT are among the most powerful consumer graphics cards available, targeting high-end gamers. These cards make 4K gaming genuinely possible, though their price tag can be prohibitive for mainstream users.
Unusual Consistency in CPU Recommendations​
Most demanding PC games ramp up CPU requirements for higher settings, particularly as resolution and effects increase. Yet, Stellar Blade’s requirements list the same CPUs (i5-8400 or Ryzen 5 3600X) at every tier except the minimum. This could reflect one of two realities:
  • Engine Limitation: Stellar Blade may be more GPU-bound, leveraging multi-core CPUs only up to a point. Such architectures favor consistent CPU recommendations for all but the lowest tier, as higher resolutions do less to tax the processor.
  • Testing Gap: It’s possible that further refinements closer to launch could change these specs, especially as testing on the full range of PC hardware wraps up.
Prospective players should monitor pre-launch updates for possible shifts, especially if aiming to maximize future-proofing. Historically, some games have quietly increased CPU recommendations in “day one” or pre-release patches.
Storage Needs: The Role of SSDs​
Every edition of Stellar Blade mandates 75 GB of free storage, which is roughly on par with other open-world or action-adventure titles. The formal allowance of an HDD at minimum requirements nods to broader PC accessibility, but the recurring recommendation for SSDs shouldn’t be ignored.
The trend in 2020s PC gaming is clear: modern games increasingly stream assets dynamically, often leading to hitching or delays on spinning disks. While the game is designed to be playable from an HDD, the user experience may suffer with long loading times, stutter, or reduced texture quality. For action games like Stellar Blade, which rely on tight combat and seamless environments, an SSD is less a luxury and more a necessity.
Frame Rate, Visual Options, and Modding Potential​
One major selling point is the promise of a completely unlocked frame rate on PC. Console players are typically capped at 30 or 60 FPS—even for the PlayStation 5 version—so the opportunity to boost frame rates on capable rigs should make for a notably smoother action experience.
Unlocked frame rates, however, are a double-edged sword:
  • Pros: Players with high-refresh monitors will benefit from ultra-smooth motion, which can enhance both moment-to-moment gameplay and overall immersion.
  • Cons: Poorly optimized ports can develop 'microstutter' or inconsistent frame pacing at uncapped settings unless properly managed. This has affected other PlayStation-to-PC ports at launch.
Additionally, as with most PC releases, expect a suite of customizable graphics options: texture filtering, draw distance, anti-aliasing modes, and more. Modding support has not yet been explicitly confirmed by Shift Up, and none of the PlayStation-to-PC ports have launched with official modding tools. However, the PC community is resourceful; games such as Days Gone and Horizon Zero Dawn saw substantial user-driven mods (from reshading to playable character swaps) within their first months on Steam.
Players seeking a tailored experience—whether it’s accessibility tweaks, visual overhauls, or even new content—should watch community forums and modding hubs after the launch.
How to Check and Upgrade Your PC: A Quick Primer​
For newcomers or unsure upgraders, checking system specs is straightforward:
  • Type “dxdiag” in the Windows taskbar.
  • Run the DirectX Diagnostic Tool.
  • Examine the System and Display tabs.
  • System gives memory and CPU details.
  • Display shows GPU specifics.
If your machine falls short—especially on GPU or RAM—desktop upgrades may be as easy as a new graphics card or adding memory modules. Upgrading a CPU, however, often means a new motherboard or a fresh build entirely, particularly if your hardware is more than a generation or two old.
High-end requirements may deter laptop users; most gaming laptops can tackle 1080p or 1440p at Medium, but only the latest flagship portables will manage 4K Very High without compromise.
Gaming Handhelds: The Steam Deck, ROG Ally, and More​
A notable segment of the PC audience now enjoys portable Windows-based gaming. Devices like the Steam Deck, ASUS ROG Ally, and Lenovo Legion Go blur the line between console and PC, promising AAA gaming from the couch or on the go.
Steam Deck: Officially Supported, with Caveats​
The Stellar Blade X (Twitter) account posted a video demonstration of the game running on a Steam Deck. Early footage and impressions indicate that, by dialing settings down (likely to Low), Deck users can achieve a smooth, playable experience—the same as on minimum-spec desktop machines. Real-world performance will likely settle at 30 to 40 FPS at low-medium graphics at 720p or 800p, Valve’s native screen resolution.
Still, this is a major advantage; many recent PlayStation ports have struggled with Steam Deck verification at launch, often requiring patches or community fixes. Shift Up’s attention to Deck compatibility is a notable strength.
ROG Ally, Legion Go, and Other Handhelds: Smooth Sailing​
Compared to the Steam Deck, Windows-powered handhelds like the ASUS ROG Ally (especially the high-end “X” variant) and Lenovo Legion Go pack significantly more powerful hardware. These systems outstrip Valve’s device in both CPU and GPU performance, suggesting they may run Stellar Blade at 60 FPS, even at higher resolutions and settings.
As is typical for Windows handhelds, thermal and battery considerations will mean users may need to manage power profiles and settings for the best balance of performance and portability.
Analyzing Stellar Blade’s PC Port: Strengths and Potential Pitfalls​
Transitioning a console-exclusive to the PC audience is never trivial. Previous PlayStation Studios PC releases have had widely varying launches—some, like Marvel’s Spider-Man, were praised for their technical polish, while others, like The Last of Us Part I, suffered from optimization woes at launch.
Key Strengths​
  • Broad Hardware Compatibility: By covering both older and brand-new hardware across the four-tier spec list, Shift Up enables a wide variety of gamers to participate.
  • Unlocked Frame Rate: The ability to run above 60 FPS for those with higher-end hardware is a significant draw.
  • Steam Deck and Handheld Support: Early confirmation and demonstration on Steam Deck signal a smooth launch for portable PC enthusiasts.
  • SSD Support and Recommendations: Proactive communication around storage needs reduces the risk of user frustration caused by unexpected performance drops.
Significant Risks and Uncertainties​
  • CPU Consistency: The unchanged CPU spec from Recommended to Very High raises questions about either parallelization in the engine or incomplete late-stage testing. Large-scale scenes, physics-heavy sequences, or AI routines could bottleneck older CPUs at high settings, and late-breaking updates to the requirements remain a possibility.
  • No Mention of DLSS/FSR at Launch: Current documentation does not specify whether NVIDIA DLSS or AMD FSR upscaling technologies will be supported. These are increasingly vital for optimizing performance, especially at 4K.
  • Modding and Community Tools: Official silence about mod support may frustrate players who have come to expect a rich modding culture for PC action games.
  • Day-One Optimization: As seen with other PlayStation ports, launch day patches are common, often needed to improve performance or resolve compatibility bugs. Until full benchmarking and user reports arrive, caution is warranted—especially for those committing to pre-orders or looking for flawless day-one experiences.
Launch Details and Availability​
Stellar Blade is slated for Windows PC (via Steam) on June 11, 2025, joining a growing list of PlayStation Studios titles accessible to the broader PC audience. Console-exclusive content, like new boss fights (for example, Mann, leader of the Sentinels), will be present in the PC edition, providing both parity and additional value for new players.
The PC Gaming Landscape: Where Does Stellar Blade Fit?​
For many, Stellar Blade represents the evolving face of cross-platform gaming. As major publishers pursue a “console first, PC soon after” release model, the expectation is no longer that games will remain console-limited. Above all, PC releases offer:
  • Choice of hardware: From budget builds, through monster desktops, to sleek handhelds.
  • Customizable visuals: PC’s scalability allows both low-end and enthusiast rigs to shine.
  • Community-driven innovation: From accessibility fixes to complete gameplay overhauls, the PC modding community often extends a game’s lifespan and reach.
Stellar Blade’s very presence on PC, with an unlocked frame rate and extensive quality presets, promises a flexible and potentially spectacular journey for players. If Shift Up and PlayStation Studios can avoid the pitfalls that dogged other ports, it could easily become one of the year’s most recommended action games.
Conclusion: Should You Prepare for EVE’s Journey?​
Stellar Blade’s PC system requirements are both reasonable and slightly uncompromising in places. 16 GB of RAM as a baseline and the push for SSD storage reflect modern expectations—if not outright necessities—for a smooth action game experience in 2025. While the GPU demands trend upward in step with expectations for 1440p and 4K play, the CPU requirements remain curiously static, warranting close attention in the weeks leading to launch.
For PC enthusiasts with modern components, especially those with high-refresh monitors and an appetite for maxed-out visuals, the port offers tantalizing potential. For others—particularly those on aging gaming laptops or rigs falling below the GPU baseline—preparing for EVE’s journey will either require upgrades or a willingness to compromise on graphical glamour.
With a firm launch date, robust hardware guidance, and early reassurance for handheld users, Stellar Blade’s PC debut is poised to be one of the most anticipated releases of the season. Yet, as always with major PC launches, cautious optimism and readiness to patch, tweak, and adjust—a hallmark of the platform—will serve prospective players well.
The ruins of Earth await. With the right hardware (and perhaps a little patience for day-one patches), the odyssey of EVE and her enemies begins anew—this time, by the power of your own custom-built machine.
Source: inkl Stellar Blade PC system requirements and specs — Can your computer run this action game?
