Windows 10 Strange beeping noise.
orchidsartanddesign
Well-Known Member
My dell computer has been making this strange beeping noise off and on when it updates, and when it starts up. Is there anyone who is an expert on computers that knows what is happening?
From the link I sent
LED/BEEP CODE
FAULT DESCRIPTION
FAULT(S)
SUGGESTED ACTION
1
Motherboard: BIOS ROM Failure​
Motherboard, covers BIOS corruption or ROM error​
Run the Link Removed
You'll need to look up the computer model on Dells site and look at the user manual. They should have a post code section. Find the pattern you hear and it should tell you what it means.
I tried doing that, but the dell website just wants me to download the support assist, and I tried to look up the version of my computer and can’t find it.
LED/BEEP CODE
FAULT DESCRIPTION
FAULT(S)
SUGGESTED ACTION
1
I ran the thorough diagnostic test on it. Does anyone know what a notebook panel is? Because it showed that there was something wrong with the notebook panel. Is the notebook panel the screen?
