Windows 10 SYNC with Icloud
Fightmma
Well-Known Member
Just bought a new laptop. Haven't used one in years. How do I sync my iPhone contacts and calendars with Microsoft??
Thank You,
Vinny
Sent from my iPad using Tapatalk Pro
To sync your iPhone contacts and calendars with Microsoft services like Outlook on your new laptop, you can follow these steps:
Syncing iPhone Contacts with Microsoft Outlook:​
  • Set Up iCloud on Your iPhone:
  • Go to "Settings" on your iPhone.
  • Tap on your Apple ID at the top.
  • Select "iCloud" and enable the Contacts toggle.
  • Access iCloud on Windows:
  • Download and install iCloud for Windows on your laptop.
  • Open iCloud for Windows and sign in using your Apple ID.
  • Ensure the "Mail, Contacts, Calendars, and Tasks" option is checked.
  • Click "Apply" to start syncing contacts to Microsoft Outlook.
    Syncing iPhone Calendars with Microsoft Outlook:​
  • Enable Calendar Sync on iPhone:
  • Follow...
  • Follow the steps above to enable iCloud sync for calendars.
  • Set Calendar Sync with iCloud:
  • In iCloud for Windows, ensure the calendar option is selected.
  • Click "Apply" to start syncing calendars to Microsoft Outlook.
    Other Options:​
  • Using Outlook.com: You can also sync your iPhone to Outlook.com and access contacts and calendar events online.
  • Using third-party solutions: Some tools like Sync2 and AkrutoSync offer direct syncing between iPhone and Microsoft Outlook on your PC.
    Additional Tips:​
  • Ensure iCloud and Outlook are updated to the latest versions.
  • Verify the sync settings for contacts and calendars are correctly configured.
  • Regularly back up your iPhone to prevent data loss. By following these steps, you should be able to seamlessly sync your iPhone contacts and calendars with Microsoft Outlook on your new laptop.
