Windows 7 system hangs 20-30 minutes after start Where to start fixing?
PeteX
some time after starting windows computer HDD will start to spin all the time (or at leasts that's what HDD LED says). This makes the system respond very slow or halt making it virtually useless - it can persist for quite a long time until the system crashes with blue screen or I reset it. Sometimes shout down will also work but it takes very long time to shoutdown in such case.
The problem does not seam to be related to any particular program.
CPU and memory loads seam reasonable (ca 30-50% for CPU and 60-70% fro RAM which are my typical loads)
Where and what for should I look for (LOGs, BSOD photos)??
Re: [langtitle=pl]Re: system hangs 20-30 minutes after start Where to start fixing?[/langtitle]
KERNEL_DATA_INPAGE_ERROR (7a)
The requested page of kernel data could not be read in. Typically caused by a bad block in the paging file or disk controller error.
1. Update drivers:
ATK64AMD.sys Fri Oct 27 08:45:25 2006
ATK0100 ACPI Utility, Motherboard
ASUS Support
athrx.sys Mon Oct 05 12:33:57 2009
Atheros CB42/CB43/MB42/MB43 Network Adapter
rimspx64.sys Thu Jul 26 07:33:52 2007
Ricoh Memorystick Controller
2. Uninstall G Data Security Software :
GDBehave.sys Tue Jul 07 09:03:06 2009
Install MSE to teplace it :
Link Removed due to 404 Error
Microsoft (R)...
[lang=pl]here they are THX[/lang]
1. Update drivers:
ASUS Support
Loading Dump File [F:\a\Minidump\D M P\111710-45443-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`03057000 PsLoadedModuleList = 0xfffff800`03294e50
Debug session time: Wed Nov 17 04:07:26.041 2010 (UTC - 5:00)
System Uptime: 0 days 10:34:42.273
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 7A, {fffff6fc40033fc8, ffffffffc0000185, 76322be0, fffff880067f9000}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+34c0e )
Followup: MachineOwner
0: kd> !analyze -v
a bad block in the paging file or disk controller error. Also see
KERNEL_STACK_INPAGE_ERROR.
If the error status is 0xC000000E, 0xC000009C, 0xC000009D or 0xC0000185,
it means the disk subsystem has experienced a failure.
If the error status is 0xC000009A, then it means the request failed because
a filesystem failed to make forward progress.
Arguments:
Arg1: fffff6fc40033fc8, lock type that was held (value 1,2,3, or PTE address)
Arg2: ffffffffc0000185, error status (normally i/o status code)
Arg3: 0000000076322be0, current process (virtual address for lock type 3, or PTE)
Arg4: fffff880067f9000, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
Debugging Details:
ERROR_CODE: (NTSTATUS) 0xc0000185 - <Unable to get error code text>
DISK_HARDWARE_ERROR: There was error with disk hardware
BUGCHECK_STR:  0x7a_c0000185
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff8000313c168 to fffff800030c7740
STACK_TEXT:
fffff880`03140888 fffff800`0313c168 : 00000000`0000007a fffff6fc`40033fc8 ffffffff`c0000185 00000000`76322be0 : nt!KeBugCheckEx
fffff880`03140890 fffff800`030b952b : fffffa80`07df6860 fffff880`031409c0 fffff800`03254440 00000000`00000001 : nt! ?? ::FNODOBFM::`string'+0x34c0e
fffff880`03140970 fffff800`030e25c4 : 00000000`00000000 00000000`00000001 ffffffff`ffffffff fffff800`030d59fd : nt!MiIssueHardFault+0x28b
fffff880`03140a00 fffff800`030bc004 : 00000000`00000001 fffff6fc`40033fa0 fffffa80`06f62700 00000000`00000000 : nt!MmAccessFault+0x11c4
fffff880`03140b60 fffff800`030bc1ec : fffffa80`0597b060 00000000`00000001 fffff800`03241e80 fffff800`03064112 : nt!MiInPageSingleKernelStack+0x134
fffff880`03140c70 fffff800`030bc187 : fffffa80`04eb9090 00000000`00000000 fffffa80`03ce95f0 00000000`00000000 : nt!MmInPageKernelStack+0x40
fffff880`03140cd0 fffff800`030bbe2c : 00000000`00000000 00000000`00000000 00000000`00000080 fffffa80`03ce95f0 : nt!KiInSwapKernelStacks+0x1f
fffff880`03140d00 fffff800`0336bc06 : 01cac3b3`e6f34bc7 01ca0417`52b0c344 00000000`00024000 00000000`00023a00 : nt!KeSwapProcessOrStack+0x84
fffff880`03140d40 fffff800`030a5c26 : fffff800`03241e80 fffffa80`03d08b60 fffff800`0324fc40 01ca0417`66ba5d23 : nt!PspSystemThreadStartup+0x5a
fffff880`03140d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`0313c168 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+34c0e
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
FAILURE_BUCKET_ID:  X64_0x7a_c0000185_nt!_??_::FNODOBFM::_string_+34c0e
0: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL:  0
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
MODULE_NAME: nt
Loading Dump File [F:\a\Minidump\D M P\111710-59483-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0305b000 PsLoadedModuleList = 0xfffff800`03298e50
Debug session time: Wed Nov 17 07:24:32.725 2010 (UTC - 5:00)
System Uptime: 0 days 1:34:35.692
BugCheck 7A, {fffff6fc40049e60, ffffffffc0000185, 11413dbe0, fffff880093cc000}
0: kd> !analyze -v
Arguments:
Arg1: fffff6fc40049e60, lock type that was held (value 1,2,3, or PTE address)
Arg3: 000000011413dbe0, current process (virtual address for lock type 3, or PTE)
Arg4: fffff880093cc000, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
Debugging Details:
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80003140168 to fffff800030cb740
STACK_TEXT:
fffff880`03140848 fffff800`03140168 : 00000000`0000007a fffff6fc`40049e60 ffffffff`c0000185 00000001`1413dbe0 : nt!KeBugCheckEx
fffff880`03140850 fffff800`030bd52b : fffffa80`069ab9b0 fffff880`031409c0 fffff800`03258440 fffff880`031409a0 : nt! ?? ::FNODOBFM::`string'+0x34c0e
fffff880`03140930 fffff800`030e65c4 : 00000000`00000000 00000000`00000001 ffffffff`ffffffff fffff800`030d99fd : nt!MiIssueHardFault+0x28b
fffff880`03140a00 fffff800`030c0004 : 00000000`00000001 fffff6fc`40049e38 fffffa80`07060000 fffff880`0846bcd0 : nt!MmAccessFault+0x11c4
fffff880`03140b60 fffff800`030c01ec : fffffa80`066bd060 00000000`00000001 fffffa80`06846b60 fffff800`030be3fb : nt!MiInPageSingleKernelStack+0x134
fffff880`03140c70 fffff800`030c0187 : fffffa80`06846b60 00000000`00000080 fffffa80`03ce95f0 fffffa80`066bd100 : nt!MmInPageKernelStack+0x40
fffff880`03140cd0 fffff800`030bfe2c : 00000000`00000000 00000000`00000000 00000000`00000080 fffffa80`03ce9500 : nt!KiInSwapKernelStacks+0x1f
fffff880`03140d00 fffff800`0336fc06 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeSwapProcessOrStack+0x84
fffff880`03140d40 fffff800`030a9c26 : fffff800`03245e80 fffffa80`03d08b60 fffff800`03253c40 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`03140168 cc              int     3
MODULE_NAME: nt
0: kd> lmsmtn
fffff880`053bc000 fffff880`053fa000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00e00000 fffff880`00e57000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02cff000 fffff880`02d89000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03a72000 fffff880`03a88000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00c76000 fffff880`00c81000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`08b46000 fffff880`08b51000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00e6a000 fffff880`00e73000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00dba000 fffff880`00de4000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`03e5d000 fffff880`03fda000   athrx    athrx.sys    Mon Oct 05 12:33:57 2009 (4ACA1FF5)
fffff880`048ad000 fffff880`048b5000   ATK64AMD ATK64AMD.sys Fri Oct 27 08:45:25 2006 (4541FF65)
fffff880`06f33000 fffff880`06fe8000   ATSwpWDF ATSwpWDF.sys Tue Nov 24 09:00:40 2009 (4B0BE708)
fffff880`00d99000 fffff880`00da5000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`019b1000 fffff880`019b8000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03b83000 fffff880`03b94000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`04788000 fffff880`047a6000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00750000 fffff960`00777000   cdd      cdd.dll      unavailable (00000000)
fffff880`0197e000 fffff880`019a8000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00e73000 fffff880`00f33000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`042ed000 fffff880`042ff000   circlass circlass.sys Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`01916000 fffff880`01946000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cf3000 fffff880`00d51000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`03e56000 fffff880`03e5a500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`01114000 fffff880`01187000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`00ff3000 fffff880`00ffc000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`03a62000 fffff880`03a72000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`06efb000 fffff880`06f09000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03ae2000 fffff880`03b65000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03b65000 fffff880`03b83000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`01242000 fffff880`01251000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01900000 fffff880`01916000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`06e61000 fffff880`06e83000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06f09000 fffff880`06f15000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06f20000 fffff880`06f33000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06f15000 fffff880`06f20000   dump_msahci dump_msahci.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`06eef000 fffff880`06efb000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`03cd7000 fffff880`03dcb000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`03c00000 fffff880`03c46000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`010a2000 fffff880`010b6000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01056000 fffff880`010a2000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`018c6000 fffff880`01900000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0148b000 fffff880`014d5000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`01235000 fffff880`01242000   GDBehave GDBehave.sys Tue Jul 07 09:03:06 2009 (4A53478A)
fffff880`018b3000 fffff880`018c3000   gdwfpcd64 gdwfpcd64.sys Mon Jul 06 21:07:21 2009 (4A529FC9)
fffff880`048a4000 fffff880`048ad000   GEARAspiWDM GEARAspiWDM.sys Fri Feb 01 09:06:03 2008 (47A3274B)
fffff880`02cd6000 fffff880`02cf5000   GRD      GRD.sys      Fri Jul 10 03:15:01 2009 (4A56EA75)
fffff800`03012000 fffff800`0305b000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`03dcb000 fffff880`03def000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04200000 fffff880`0425c000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`06eb2000 fffff880`06ecb000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`06ea1000 fffff880`06eb2000   hidir    hidir.sys    Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`06ecb000 fffff880`06ed3080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`06e1d000 fffff880`06e2b000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`08a9d000 fffff880`08aac000   HookCentre HookCentre.sys Fri Jun 19 06:27:04 2009 (4A3B67F8)
fffff880`04600000 fffff880`046c8000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`014ed000 fffff880`014f6000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04877000 fffff880`04895000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`03bba000 fffff880`03bd0000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`03a00000 fffff880`03a62000   itecir   itecir.sys   Tue Jul 13 05:50:47 2010 (4C3C36F7)
fffff880`03def000 fffff880`03dfe000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`06ed4000 fffff880`06ee2000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bce000 fffff800`00bd8000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`042aa000 fffff880`042ed000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`06e83000 fffff880`06e88200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`046eb000 fffff880`04700000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01946000 fffff880`01969000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c9b000 fffff880`00cdf000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`08aac000 fffff880`08ac2000   MiniIcpt MiniIcpt.sys Mon Jun 29 10:26:23 2009 (4A48CF0F)
fffff880`06fe8000 fffff880`06ff6000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04895000 fffff880`048a4000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`06ee2000 fffff880`06eef000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00c5c000 fffff880`00c76000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`047a6000 fffff880`047be000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`047be000 fffff880`047eb000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`086bc000 fffff880`0870a000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0870a000 fffff880`0872d000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`00de4000 fffff880`00def000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0181b000 fffff880`01826000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e60000 fffff880`00e6a000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010b6000 fffff880`01114000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02ccb000 fffff880`02cd6000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`015ea000 fffff880`015fc000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014f8000 fffff880`015ea000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03aac000 fffff880`03ab8000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04753000 fffff880`04766000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`03bd0000 fffff880`03bff000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`043d5000 fffff880`043ea000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02c2a000 fffff880`02c39000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d89000 fffff880`02dce000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`01826000 fffff880`01837000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02cbf000 fffff880`02ccb000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0305b000 fffff800`03637000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01259000 fffff880`013fc000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`019a8000 fffff880`019b1000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`053ba000 fffff880`053bb180   nvBridge nvBridge.kmd Thu Jul 02 02:48:10 2009 (4A4C582A)
fffff880`06e89000 fffff880`06ea1000   nvhda64v nvhda64v.sys Fri Aug 21 16:23:50 2009 (4A8F0256)
fffff880`048bd000 fffff880`053b9d80   nvlddmkm nvlddmkm.sys Thu Jul 02 03:40:25 2009 (4A4C6469)
fffff880`04700000 fffff880`04753000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02dd7000 fffff880`02dfd000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00d84000 fffff880`00d99000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d51000 fffff880`00d84000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00def000 fffff880`00dff000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`0872d000 fffff880`087d3000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`08ac2000 fffff880`08ad5000   PktIcpt  PktIcpt.sys  Sun Aug 09 07:42:24 2009 (4A7EB620)
fffff880`0425c000 fffff880`04299000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cdf000 fffff880`00cf3000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`03a88000 fffff880`03aac000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03ab8000 fffff880`03ad3000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`011d3000 fffff880`011f4000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`0103a000 fffff880`01054000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`01862000 fffff880`018b3000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`03ad3000 fffff880`03ade000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01800000 fffff880`01809000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01809000 fffff880`01812000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01812000 fffff880`0181b000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01000000 fffff880`0103a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`03fe7000 fffff880`03ffd000   rimmpx64 rimmpx64.sys Tue Jun 24 00:50:08 2008 (48607D00)
fffff880`03cba000 fffff880`03cd1000   rimspx64 rimspx64.sys Thu Jul 26 07:33:52 2007 (46A886A0)
fffff880`04820000 fffff880`04877000   rixdpx64 rixdpx64.sys Fri Jul 27 06:45:50 2007 (46A9CCDE)
fffff880`04766000 fffff880`0477e000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`03e00000 fffff880`03e56000   Rt64win7 Rt64win7.sys Wed Jun 23 05:10:45 2010 (4C21CF95)
fffff880`04800000 fffff880`04820000   sdbus    sdbus.sys    Fri Oct 09 22:41:20 2009 (4ACFF450)
fffff880`087d3000 fffff880`087de000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`014e5000 fffff880`014ed000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`08a07000 fffff880`08a9d000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`0863f000 fffff880`086a6000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`08600000 fffff880`0862d000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`03e5b000 fffff880`03e5c480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`0862d000 fffff880`0863f000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`01855000 fffff880`01862000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01837000 fffff880`01855000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02cab000 fffff880`02cbf000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004f0000 fffff960`004fa000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03b94000 fffff880`03bba000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`042ff000 fffff880`04311000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`06e00000 fffff880`06e1d000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`0433d000 fffff880`0433ef00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`03ca9000 fffff880`03cba000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0437b000 fffff880`043d5000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`03c53000 fffff880`03ca9000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0432e000 fffff880`0433d000   usbrpm   usbrpm.sys   Mon Jul 13 20:35:14 2009 (4A5BD2C2)
fffff880`03c46000 fffff880`03c53000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`06e2b000 fffff880`06e58200   usbvideo usbvideo.sys Wed Mar 03 23:40:57 2010 (4B8F39D9)
fffff880`00fe6000 fffff880`00ff3000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`019b8000 fffff880`019c6000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`019c6000 fffff880`019eb000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`014d5000 fffff880`014e5000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00da5000 fffff880`00dba000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`01187000 fffff880`011d3000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`0433f000 fffff880`0437b000   vpchbus  vpchbus.sys  Tue Sep 22 21:32:32 2009 (4AB97AB0)
fffff880`02c16000 fffff880`02c2a000   vpcnfltr vpcnfltr.sys Tue Sep 22 21:32:30 2009 (4AB97AAE)
fffff880`04311000 fffff880`0432e000   vpcusb   vpcusb.sys   Tue Sep 22 21:32:39 2009 (4AB97AB7)
fffff880`02c54000 fffff880`02caa180   vpcvmm   vpcvmm.sys   Tue Sep 22 21:32:38 2009 (4AB97AB6)
fffff880`03fda000 fffff880`03fe7000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`02c00000 fffff880`02c16000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`0477e000 fffff880`04788000   vwifimp  vwifimp.sys  Mon Jul 13 20:07:28 2009 (4A5BCC40)
fffff880`02c39000 fffff880`02c54000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`019eb000 fffff880`019fb000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00f33000 fffff880`00fd7000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00fd7000 fffff880`00fe6000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02dce000 fffff880`02dd7000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00040000 fffff960`0034f000   win32k   win32k.sys   unavailable (00000000)
fffff880`00e57000 fffff880`00e60000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`046ca000 fffff880`046eb000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`08ad5000 fffff880`08b46000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01946000 fffff880`01954000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01954000 fffff880`01960000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01960000 fffff880`0196b000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`0196b000 fffff880`0197e000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
after couple days of testing I can say this unfortunately did not solve the problem. Even though it seams it's less frequent now (but that's just my impression so hard to judge on that)
