gear2014
all the icons on my screen have gone white and i cant click anything not even the start button. when i bring up the task manager all it is is a white box. i can login in fine but that is it. when i try torestore nothing happens, i dont have any restore points so i dont want to do a complete restore if i can avoid it. i have tried running chkdsk in safe mode but nothing has worked. i have also run avg rescue cd form a usb and it identified a trojan but i deleted it, still no effect. i have also tried using the recovery cd i got with my samsung laptop but can only use the startup check tool. this comes back with no issues but i cant use any of the other options.
any help would be greatly appreciated!!
Try running a system file check (in safe mode if necessary):
run command prompt as administrator and enter the command:
sfc /scannow
sfc /scannow
You could try an inplace install boot to windows insert your WIN7 DVD and see if it come up. This will allow you to do a reinstall of windows without formating the drive.
You should backup any important files if not already done so before doing this.
I have never tried this in safe mode but it work there also.
