Windows 8 System_thread_exception_not_handled error, monitor related?
Ross Kielman
Hello, I've been getting some pretty consistent BSOD's of late, usually through interaction with my laptop monitor. Closing the lid, disabling the monitor's driver and occasionally when leaving it to timeout/standby.
Any help will be appreciated!
  • W7F_16-04-2013.rar
    W7F_16-04-2013.rar
  • RAMMon - SPD Info.txt
Your BIOS dates from 2010. Please check at the manufacturer's website to see if there are any BIOS updates available for your system. Also check the readme file to see if they apply to the problems that you are having. Please be advised that flashing the BIOS is a very unforgiving process - and one mistake can physically damage your motherboard.
C: drive only haas about 4% free space. D: drive only has about 8% free space. H: drive has less than 1% free space. Windows likes 15% free space in order to perform stuff "behind the scenes" without adversely affecting the system's performance. Please free up 15% on ALL hard drives (you can get away with 10% on larger drives and won't notice a large performance penalty)
I have...
usasma
Fantastic Member
I have seen issues when using both the Logitech Setpoint utilities and the Microsoft keyboard/mouse utilities together.
I'd suggest removing one or the other.
Please remove the Western Digital software as it's drivers date from 2008 and are known to cause BSOD's on some Windows systems.
HpqKbFiltr.sys Wed Apr 29 09:48:30 2009 (49F85AAE)
HP Quick Launch Buttons HpqKbFiltr Keyboard Filter driver
HECIx64.sys Thu Sep 17 15:54:16 2009 (4AB293E8)
Intel Management Engine Interface
stwrt64.sys Tue Oct 20 11:42:09 2009 (4ADDDA51)
SigmaTel High Definition Audio Codec
LGVirHid.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
Logitech Gamepanel Virtual HID Device Driver
LGBusEnum.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
Logitech Keyboard
Accelerometer.sys Fri May 13 14:47:02 2011 (4DCD7CA6)
HP Mobile Data Protection System Accelerometer
hpdskflt.sys Fri May 13 14:47:02 2011 (4DCD7CA6)
HP Mobile Data Protection System Disk Filter
SynTP.sys Thu Oct 13 22:34:52 2011 (4E979FCC)
Synaptic Touch Pad Driver
Rt630x64.sys Wed Oct 19 08:12:55 2011 (4E9EBEC7)
Realtek PCI/PCIe Adapters
If all of this doesn't stop the BSOD's, please run Driver Verifier according to these instructions: Link Removed
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Mon Apr 15 21:34:05.279 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041613-22609-01.dmp]
Windows 8 Kernel Version 9200 MP (4 procs) Free x64
Built by: [B]9200[/B].16551.amd64fre.win8_gdr.130306-1502
System Uptime:[B]0 days 0:12:51.946[/B]
*** ERROR: Module load completed but symbols could not be loaded for monitor.sys
*** ERROR: Module load completed but symbols could not be loaded for Wdf01000.sys
Probably caused by :[B]monitor.sys ( monitor+89b8 )[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff8000d8b39c3, fffff88002d391b8, fffff88002d389f0}[/B]
BugCheck Info: [B]Link Removed[/B]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8000d8b39c3, The address that the exception occurred at
Arg3: fffff88002d391b8, Exception Record Address
Arg4: fffff88002d389f0, Context Record Address
PROCESS_NAME:  System
BUGCHECK_STR:  AV
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
FAILURE_BUCKET_ID: [B]AV_monitor+89b8[/B]
CPUID:        "Intel(R) Core(TM) i5 CPU       M 540  @ 2.53GHz"
MaxSpeed:     2530
CurrentSpeed: [B]2527[/B]
  BIOS Version                  F.08
  BIOS Release Date             07/08/2010
  Manufacturer                  Hewlett-Packard
  Product Name                  HP ENVY 17 NoteBook PC
**************************Mon Apr 15 21:20:42.712 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041613-28109-01.dmp]
System Uptime:[B]0 days 0:12:43.378[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff803f890f9c3, fffff88002d631b8, fffff88002d629f0}[/B]
Arguments:
Arg2: fffff803f890f9c3, The address that the exception occurred at
Arg3: fffff88002d631b8, Exception Record Address
Arg4: fffff88002d629f0, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Mon Apr 15 21:07:15.529 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041613-35718-01.dmp]
System Uptime:[B]0 days 10:11:10.225[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff801a050c9c3, fffff8800af7d0c8, fffff8800af7c900}[/B]
Arguments:
Arg2: fffff801a050c9c3, The address that the exception occurred at
Arg3: fffff8800af7d0c8, Exception Record Address
Arg4: fffff8800af7c900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Mon Apr 15 10:49:15.929 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041513-50156-01.dmp]
Built by: [B]9200[/B].16496.amd64fre.win8_gdr.130108-1504
System Uptime:[B]4 days 13:41:28.850[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff802b78e3cf3, fffff8800a10e678, fffff8800a10deb0}[/B]
Arguments:
Arg2: fffff802b78e3cf3, The address that the exception occurred at
Arg3: fffff8800a10e678, Exception Record Address
Arg4: fffff8800a10deb0, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Mon Apr  8 18:11:33.078 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040913-82171-01.dmp]
System Uptime:[B]1 days 5:14:43.763[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff8003b8f2cf3, fffff8800a7400c8, fffff8800a73f900}[/B]
Arguments:
Arg2: fffff8003b8f2cf3, The address that the exception occurred at
Arg3: fffff8800a7400c8, Exception Record Address
Arg4: fffff8800a73f900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Sun Apr  7 12:56:15.216 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040813-37093-01.dmp]
System Uptime:[B]3 days 22:27:52.264[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff803a9672cf3, fffff880075410c8, fffff88007540900}[/B]
Arguments:
Arg2: fffff803a9672cf3, The address that the exception occurred at
Arg3: fffff880075410c8, Exception Record Address
Arg4: fffff88007540900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Wed Apr  3 14:27:18.569 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040413-37468-01.dmp]
System Uptime:[B]1 days 16:59:28.232[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff801ad8e8cf3, fffff8800b7420c8, fffff8800b741900}[/B]
Arguments:
Arg2: fffff801ad8e8cf3, The address that the exception occurred at
Arg3: fffff8800b7420c8, Exception Record Address
Arg4: fffff8800b741900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Mon Apr  1 21:27:03.014 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040213-17671-01.dmp]
System Uptime:[B]0 days 6:41:30.716[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff8035c073cf3, fffff88002bf70c8, fffff88002bf6900}[/B]
Arguments:
Arg2: fffff8035c073cf3, The address that the exception occurred at
Arg3: fffff88002bf70c8, Exception Record Address
Arg4: fffff88002bf6900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Mon Apr  1 14:45:00.414 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040213-20890-01.dmp]
System Uptime:[B]1 days 2:36:13.081[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff802818f9cf3, fffff8800bd2f0c8, fffff8800bd2e900}[/B]
Arguments:
Arg2: fffff802818f9cf3, The address that the exception occurred at
Arg3: fffff8800bd2f0c8, Exception Record Address
Arg4: fffff8800bd2e900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Sun Mar 31 12:08:08.945 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040113-18312-01.dmp]
System Uptime:[B]3 days 9:17:33.335[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff801bde7acf3, fffff880099670c8, fffff88009966900}[/B]
Arguments:
Arg2: fffff801bde7acf3, The address that the exception occurred at
Arg3: fffff880099670c8, Exception Record Address
Arg4: fffff88009966900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Thu Mar 28 02:49:16.985 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032813-34953-01.dmp]
System Uptime:[B]1 days 0:41:32.652[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff803a4adfcf3, fffff880091bc0c8, fffff880091bb900}[/B]
Arguments:
Arg2: fffff803a4adfcf3, The address that the exception occurred at
Arg3: fffff880091bc0c8, Exception Record Address
Arg4: fffff880091bb900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Wed Mar 27 02:06:36.542 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032713-17515-01.dmp]
System Uptime:[B]0 days 13:04:02.205[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff803c607acf3, fffff8800831f0c8, fffff8800831e900}[/B]
Arguments:
Arg2: fffff803c607acf3, The address that the exception occurred at
Arg3: fffff8800831f0c8, Exception Record Address
Arg4: fffff8800831e900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Tue Mar 26 13:02:07.410 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032713-17750-01.dmp]
System Uptime:[B]0 days 1:26:13.077[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff8011868ccf3, fffff880088bc0c8, fffff880088bb900}[/B]
Arguments:
Arg2: fffff8011868ccf3, The address that the exception occurred at
Arg3: fffff880088bc0c8, Exception Record Address
Arg4: fffff880088bb900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Tue Mar 26 11:34:57.084 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032613-32156-01.dmp]
System Uptime:[B]0 days 6:56:08.747[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff80174674cf3, fffff8800a7090c8, fffff8800a708900}[/B]
Arguments:
Arg2: fffff80174674cf3, The address that the exception occurred at
Arg3: fffff8800a7090c8, Exception Record Address
Arg4: fffff8800a708900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Tue Mar 26 04:37:53.986 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032613-18796-01.dmp]
System Uptime:[B]0 days 5:28:59.653[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff803572e0cf3, fffff88006e7d0c8, fffff88006e7c900}[/B]
Arguments:
Arg2: fffff803572e0cf3, The address that the exception occurred at
Arg3: fffff88006e7d0c8, Exception Record Address
Arg4: fffff88006e7c900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Mon Mar 25 23:07:49.051 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032613-39234-01.dmp]
System Uptime:[B]5 days 8:20:51.868[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff80256a75cf3, fffff880091410c8, fffff88009140900}[/B]
Arguments:
Arg2: fffff80256a75cf3, The address that the exception occurred at
Arg3: fffff880091410c8, Exception Record Address
Arg4: fffff88009140900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Wed Mar 20 14:45:00.433 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032113-63312-01.dmp]
System Uptime:[B]1 days 9:54:31.763[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff8005f4f4cf3, fffff88006bfa0c8, fffff88006bf9900}[/B]
Arguments:
Arg2: fffff8005f4f4cf3, The address that the exception occurred at
Arg3: fffff88006bfa0c8, Exception Record Address
Arg4: fffff88006bf9900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Tue Mar 19 04:49:45.031 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031913-16687-01.dmp]
System Uptime:[B]0 days 6:44:29.698[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff803f36f9cf3, fffff88009c840c8, fffff88009c83900}[/B]
Arguments:
Arg2: fffff803f36f9cf3, The address that the exception occurred at
Arg3: fffff88009c840c8, Exception Record Address
Arg4: fffff88009c83900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Mon Mar 18 22:04:46.033 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031913-18781-01.dmp]
System Uptime:[B]0 days 15:13:24.735[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff8014ac74cf3, fffff8800821b0c8, fffff8800821a900}[/B]
Arguments:
Arg2: fffff8014ac74cf3, The address that the exception occurred at
Arg3: fffff8800821b0c8, Exception Record Address
Arg4: fffff8800821a900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Mon Mar 18 06:50:41.532 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031813-19031-01.dmp]
System Uptime:[B]0 days 9:30:00.199[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff801428e9cf3, fffff88008d760c8, fffff88008d75900}[/B]
Arguments:
Arg2: fffff801428e9cf3, The address that the exception occurred at
Arg3: fffff88008d760c8, Exception Record Address
Arg4: fffff88008d75900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Sun Mar 17 21:20:12.031 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031813-16828-01.dmp]
System Uptime:[B]0 days 8:07:06.699[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff800eda8dcf3, fffff88008f8f0c8, fffff88008f8e900}[/B]
Arguments:
Arg2: fffff800eda8dcf3, The address that the exception occurred at
Arg3: fffff88008f8f0c8, Exception Record Address
Arg4: fffff88008f8e900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Sun Mar 17 13:12:23.139 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031813-28781-01.dmp]
System Uptime:[B]1 days 0:40:17.774[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff801d66dbcf3, fffff880097070c8, fffff88009706900}[/B]
Arguments:
Arg2: fffff801d66dbcf3, The address that the exception occurred at
Arg3: fffff880097070c8, Exception Record Address
Arg4: fffff88009706900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Sat Mar 16 12:31:13.185 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031713-38937-01.dmp]
System Uptime:[B]2 days 5:09:11.223[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff802af2e1cf3, fffff88009e290c8, fffff88009e28900}[/B]
Arguments:
Arg2: fffff802af2e1cf3, The address that the exception occurred at
Arg3: fffff88009e290c8, Exception Record Address
Arg4: fffff88009e28900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Thu Mar 14 07:21:22.047 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031413-18578-01.dmp]
System Uptime:[B]2 days 1:18:45.666[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff800c768bcf3, fffff8800aeb50c8, fffff8800aeb4900}[/B]
Arguments:
Arg2: fffff800c768bcf3, The address that the exception occurred at
Arg3: fffff8800aeb50c8, Exception Record Address
Arg4: fffff8800aeb4900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Tue Mar 12 06:01:49.336 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031213-32093-01.dmp]
System Uptime:[B]0 days 18:23:29.995[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff800e988ccf3, fffff88009d1e0c8, fffff88009d1d900}[/B]
Arguments:
Arg2: fffff800e988ccf3, The address that the exception occurred at
Arg3: fffff88009d1e0c8, Exception Record Address
Arg4: fffff88009d1d900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Mon Mar 11 11:37:51.821 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031113-18781-01.dmp]
System Uptime:[B]0 days 11:25:46.649[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff80027279cf3, fffff8800976a0c8, fffff88009769900}[/B]
Arguments:
Arg2: fffff80027279cf3, The address that the exception occurred at
Arg3: fffff8800976a0c8, Exception Record Address
Arg4: fffff88009769900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Mon Mar 11 00:11:26.191 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031113-22781-01.dmp]
System Uptime:[B]1 days 10:34:02.858[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff8007967ecf3, fffff880084180c8, fffff88008417900}[/B]
Arguments:
Arg2: fffff8007967ecf3, The address that the exception occurred at
Arg3: fffff880084180c8, Exception Record Address
Arg4: fffff88008417900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Sat Mar  9 13:36:56.255 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-29765-01.dmp]
System Uptime:[B]0 days 5:51:37.922[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff801c3ef3cf3, fffff8800a1bf0c8, fffff8800a1be900}[/B]
Arguments:
Arg2: fffff801c3ef3cf3, The address that the exception occurred at
Arg3: fffff8800a1bf0c8, Exception Record Address
Arg4: fffff8800a1be900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Sat Mar  9 07:44:51.535 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030913-40312-01.dmp]
System Uptime:[B]0 days 0:00:53.203[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff8016de74cf3, fffff88002f630c8, fffff88002f62900}[/B]
Arguments:
Arg2: fffff8016de74cf3, The address that the exception occurred at
Arg3: fffff88002f630c8, Exception Record Address
Arg4: fffff88002f62900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Sat Mar  9 07:43:18.589 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030913-33531-01.dmp]
System Uptime:[B]3 days 18:50:07.101[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff8003f088cf3, fffff8800abb80c8, fffff8800abb7900}[/B]
Arguments:
Arg2: fffff8003f088cf3, The address that the exception occurred at
Arg3: fffff8800abb80c8, Exception Record Address
Arg4: fffff8800abb7900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Tue Mar  5 12:52:37.615 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030613-34703-01.dmp]
System Uptime:[B]0 days 14:08:43.278[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff80251efacf3, fffff8800701b0c8, fffff8800701a900}[/B]
Arguments:
Arg2: fffff80251efacf3, The address that the exception occurred at
Arg3: fffff8800701b0c8, Exception Record Address
Arg4: fffff8800701a900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Mon Mar  4 22:43:16.048 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030513-53843-01.dmp]
System Uptime:[B]1 days 0:02:41.697[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff80045686cf3, fffff8800868b0c8, fffff8800868a900}[/B]
Arguments:
Arg2: fffff80045686cf3, The address that the exception occurred at
Arg3: fffff8800868b0c8, Exception Record Address
Arg4: fffff8800868a900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Sun Mar  3 22:36:14.590 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030413-67000-01.dmp]
Built by: [B]9200[/B].16442.amd64fre.win8_gdr.121023-1503
System Uptime:[B]0 days 0:03:02.257[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff801672ea1d3, fffff88002d160c8, fffff88002d15900}[/B]
Arguments:
Arg2: fffff801672ea1d3, The address that the exception occurred at
Arg3: fffff88002d160c8, Exception Record Address
Arg4: fffff88002d15900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
**************************Sun Mar  3 22:32:35.778 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030413-58250-01.dmp]
System Uptime:[B]1 days 18:18:26.342[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff80009afc1d3, fffff8800b0a00c8, fffff8800b09f900}[/B]
Arguments:
Arg2: fffff80009afc1d3, The address that the exception occurred at
Arg3: fffff8800b0a00c8, Exception Record Address
Arg4: fffff8800b09f900, Context Record Address
BUGCHECK_STR:  AV
MaxSpeed:     2530
  BIOS Version                  F.08
[/font]
3rd Party Drivers:
[B]HpqKbFiltr.sys              Wed Apr 29 09:48:30 2009 (49F85AAE)[/B]
[B]HECIx64.sys                 Thu Sep 17 15:54:16 2009 (4AB293E8)[/B]
[B]stwrt64.sys                 Tue Oct 20 11:42:09 2009 (4ADDDA51)[/B]
[B]LGBusEnum.sys               Mon Nov 23 20:36:48 2009 (4B0B38B0)[/B]
[B]LGVirHid.sys                Mon Nov 23 20:36:48 2009 (4B0B38B0)[/B]
[B]hpdskflt.sys                Fri May 13 14:47:02 2011 (4DCD7CA6)[/B]
[B]Accelerometer.sys           Fri May 13 14:47:02 2011 (4DCD7CA6)[/B]
[B]SynTP.sys                   Thu Oct 13 22:34:52 2011 (4E979FCC)[/B]
[B]Rt630x64.sys                Wed Oct 19 08:12:55 2011 (4E9EBEC7)[/B]
bcmwl63a.sys                Tue Mar 13 20:31:05 2012 (4F5FE6C9)
dump_storahci.sys           Wed Jul 25 22:30:35 2012 (5010ABCB)
SCDEmu.SYS                  Fri Aug 17 00:19:38 2012 (502DC65A)
AtihdW86.sys                Tue Aug 21 22:26:37 2012 (5034435D)
LHidFilt.Sys                Tue Sep 18 05:26:53 2012 (50583E5D)
LMouFilt.Sys                Tue Sep 18 05:26:58 2012 (50583E62)
AVVideoCard.sys             Mon Sep 24 21:11:51 2012 (506104D7)
sthid.sys                   Fri Oct 19 01:28:41 2012 (5080E509)
lvbflt64.sys                Mon Oct 22 22:10:38 2012 (5085FC9E)
lvrs64.sys                  Mon Oct 22 22:11:24 2012 (5085FCCC)
lvuvc64.sys                 Mon Oct 22 22:12:08 2012 (5085FCF8)
intelppm.sys                Mon Nov  5 22:55:02 2012 (50988A16)
atikmpag.sys                Wed Dec 19 14:32:55 2012 (50D21667)
atikmdag.sys                Wed Dec 19 15:38:55 2012 (50D225DF)
intelppm.sys                Wed Jul 25 22:26:48 2012 (5010AAE8)
AVVideoCardMirror.sys       Mon Sep 24 21:11:51 2012 (506104D7)
[B]wdcsam64.sys                Wed Apr 16 04:39:08 2008 (4805BB2C)[/B]
[/font]
sthid.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
AVVideoCardMirror.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
