Windows 7 Taskbar running programs acting differently
User28
Taskbar acting weird :
I don't exactly know what made it change to this way but I think it has something to do with Advance SystemCare application. I had done Turbo Boost on my system.
Why does it take the full taskbar when only one application is running
Please help.
Hi
Because you are running Windows Classic theme it works differently.
I'm not sure where the options are but if you right click on the start button there are a lot of options you can check or uncheck.
Since you don't seem to like the Widows 7 interface you might be interested in Classic Shell.
Classic Shell | Free software downloads at SourceForge.net
It makes the interface work more like the Windows XP interface.
I use it myself and you can switch back and forth with a click
It also makes Windows Explorer work better.
Mike
Your picture is too small to be of any help.
I have ASC and do not see this issue.
The task bar is changable in size. Right click on TB, if lock task bar is checked uncheck and then you should be able to resize the TB.
I'm not sure this is you probelm just a best guess at this time.
@ helpifIcan, If you click on the inline images that he provided it should produce a reasonably sized image for your viewing.
User28;
Try right click the taskbar and choosing properties
Under the taskbar tab of the resultant dialog box try change the value of
Taskbar buttons: to
Always combine, hide labels
And see if that makes any difference.
Let us know
Regards
Randy
No that's not the problem, if you click on the image once it would automatically zoom in, pretty vbullient function. Or still if you find it difficult I will upload it on imgur or imageshack if required.
User28;
Taskbar buttons: to
Let us know
Regards
Randy
Thank you randy for the warm welcome.
I tried to change the setting to always combine, no use that crappy cascade is still there :(
Hi
Mike
