usasma
Fantastic Member
This is a test of a new output for the programs that I use.
Don't know how it's gonna display here at W7F
Age of System: Unknown
Recommendations are listed at the bottom of the post....
Device Concerns:
NETGEAR WNDA4100 N900 Wireless Dual Band USB Adapter
I do not recommend using wireless USB devices. Especially in Win7 systems.
These wireless USB devices have many issues with Win7 - and using Vista drivers with them is almost sure to cause a BSOD.
Should you want to keep using these devices, be sure to have Win7 drivers - DO NOT use Vista drivers!!!
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
Although your drivers are more recent, I've still experienced issues with these devices.
Hardware errors in the memory dumps. I suggest running these free diagnostics to ensure that there's no obvious hardware problems causing the BSOD's: Link Removed - Invalid URL
Software Concerns:
AMD OverDrive - Known to cause BSOD's in Win7 systems
Gigabyte Easy Tune 6 (ET6)- Known to cause BSOD's in Win7 systems
Gigabyte Easy Saver- Known to cause BSOD's in Win7 systems
Gigabyte Apple Charger- Known to cause BSOD's in Win7 systems (feel free to reinstall once the system is made stable again)
Overclocking - remove any overclock until the system is made stable again - then feel free to resume it once you're sure that the system will remain stable.
Analysis:
[FONT=lucida console]**************************Tue Aug  7 18:02:07.398 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\080712-14071-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 3:05:56.553[/B]
BugCheck Code: [B]BugCheck 3B, {c000001d, fffff96000077aea, fffff880074cff70, 0}[/B]
Probably caused by :[B]memory_corruption[/B]
BugCheck Info: [B]SYSTEM_SERVICE_EXCEPTION (3b)[/B]
DEFAULT_BUCKET_ID:  CODE_CORRUPTION
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]java.exe[/B]
FAILURE_BUCKET_ID: [B]X64_MEMORY_CORRUPTION_ONE_BIT[/B]
  BIOS Version                  FB
  BIOS Release Date             08/26/2011
  Manufacturer                  Gigabyte Technology Co., Ltd.
  Product Name                  M68MT-S2
**************************Mon Aug  6 12:04:15.193 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\080612-16738-01.dmp]
System Uptime:[B]0 days 1:24:58.348[/B]
BugCheck Code: [B]BugCheck A, {fffff8000743dff0, 2, 1, fffff800032d3cdf}[/B]
BugCheck Info: [B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
BUGCHECK_STR:  0xA
  BIOS Version                  FB
**************************Mon Aug  6 10:38:14.171 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\080612-14648-01.dmp]
System Uptime:[B]0 days 13:55:44.567[/B]
BugCheck Code: [B]BugCheck 50, {fffff880fffff878, 0, fffff800035773fc, 5}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ObpWaitForMultipleObjects+2c6 )[/B]
BugCheck Info: [B]PAGE_FAULT_IN_NONPAGED_AREA (50)[/B]
BUGCHECK_STR:  0x50
PROCESS_NAME: [B]Steam.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x50_nt!ObpWaitForMultipleObjects+2c6[/B]
  BIOS Version                  FB
**************************Sun Aug  5 20:41:27.277 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\080512-19032-01.dmp]
System Uptime:[B]0 days 6:11:44.674[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffff800033b6dd3, 0, ff6c}[/B]
Probably caused by :[B]afd.sys ( afd! ?? ::NNGAKEGL::`string'+2aa8 )[/B]
BugCheck Info: [B]KMODE_EXCEPTION_NOT_HANDLED (1e)[/B]
BUGCHECK_STR:  0x1E_c0000005_R
PROCESS_NAME: [B]dndclient.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_afd!_??_::NNGAKEGL::_string_+2aa8[/B]
  BIOS Version                  FB
**************************Sun Aug  5 14:29:03.424 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\080512-19531-01.dmp]
System Uptime:[B]0 days 22:07:29.072[/B]
BugCheck Code: [B]BugCheck 1E, {0, 0, 0, 0}[/B]
Probably caused by :[B]hardware ( nt!KiKernelCalloutExceptionHandler+e )[/B]
BUGCHECK_STR:  0x1E
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_IP_MISALIGNED[/B]
  BIOS Version                  FB
**************************Sat Aug  4 14:20:04.119 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\080412-27612-01.dmp]
System Uptime:[B]0 days 0:50:03.274[/B]
Probably caused by :[B]Unknown_Image ( ANALYSIS_INCONCLUSIVE )[/B]
BUGCHECK_STR:  0x1E
PROCESS_NAME: [B]csrss.exe[/B]
  BIOS Version                  FB
**************************Sat Aug  4 12:56:40.907 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\080412-22526-01.dmp]
System Uptime:[B]0 days 22:27:18.396[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiKernelCalloutExceptionHandler+e )[/B]
BUGCHECK_STR:  0x1E
FAILURE_BUCKET_ID: [B]X64_0x1E_nt!KiKernelCalloutExceptionHandler+e[/B]
  BIOS Version                  FB
**************************Thu Aug  2 19:43:31.965 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\080212-66035-01.dmp]
System Uptime:[B]0 days 7:32:40.370[/B]
BugCheck Code: [B]BugCheck D1, {fffff78400000008, 2, 0, fffff880018dae7d}[/B]
BugCheck Info: [B]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/B]
BUGCHECK_STR:  0xD1
PROCESS_NAME: [B]Rainmeter.exe[/B]
  BIOS Version                  FB
**************************Thu Aug  2 12:10:05.766 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\080212-29000-01.dmp]
System Uptime:[B]0 days 13:44:05.921[/B]
BUGCHECK_STR:  0x1E
  BIOS Version                  FB
**************************Wed Aug  1 22:24:56.308 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\080112-23384-01.dmp]
System Uptime:[B]0 days 5:27:58.368[/B]
Probably caused by :[B]amdppm.sys ( amdppm!ReadGenAddr+18 )[/B]
BUGCHECK_STR:  0x1E
FAILURE_BUCKET_ID: [B]X64_0x1E_amdppm!ReadGenAddr+18[/B]
  BIOS Version                  FB
**************************Wed Aug  1 16:56:20.036 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\080112-22807-01.dmp]
System Uptime:[B]0 days 5:36:45.096[/B]
BugCheck Code: [B]BugCheck E4, {1, fffff800034c9660, 1, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+104aa )[/B]
BugCheck Info: [B]WORKER_INVALID (e4)[/B]
BUGCHECK_STR:  0xE4
FAILURE_BUCKET_ID: [B]X64_0xE4_nt!_??_::FNODOBFM::_string_+104aa[/B]
  BIOS Version                  FB
**************************Wed Aug  1 11:18:33.064 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\080112-31153-01.dmp]
System Uptime:[B]0 days 11:12:06.219[/B]
BUGCHECK_STR:  0x1E
PROCESS_NAME: [B]svchost.exe[/B]
  BIOS Version                  FB
[/FONT]
3rd Party Drivers:
The following is for information purposes only. Any drivers in red should be removed/updated.
See the links below this table for additional information/sources for these drivers.
GEARAspiWDM.sys        Mon May 18 08:17:04 2009 (4A1151C0)
mcupdate.dll           Mon Jul 13 21:29:09 2009 (4A5BDF65)
amdiox64.sys           Thu Feb 18 10:17:53 2010 (4B7D5A21)
nvmf6264.sys           Thu Mar  4 20:04:39 2010 (4B9058A7)
amdxata.sys            Fri Mar 19 12:18:18 2010 (4BA3A3CA)
nvstor.sys             Fri Mar 19 16:45:11 2010 (4BA3E257)
nvstor64.sys           Fri Apr  9 05:22:41 2010 (4BBEF1E1)
AppleCharger.sys       Mon Jan 10 04:57:29 2011 (4D2AD809)
NetgearUDSTcpBus.sys   Thu Jun 16 02:38:59 2011 (4DF9A503)
NetgearUDSMBus.sys     Thu Jun 16 02:45:37 2011 (4DF9A691)
RTKVHD64.sys           Tue Jul 19 08:52:18 2011 (4E257E02)
Sftvollh.sys           Fri Sep 30 12:42:46 2011 (4E85F186)
Sftplaylh.sys          Fri Sep 30 12:43:05 2011 (4E85F199)
Sftfslh.sys            Fri Sep 30 12:43:06 2011 (4E85F19A)
Sftredirlh.sys         Fri Sep 30 12:43:14 2011 (4E85F1A2)
netr28ux.sys           Thu Jan  5 07:44:48 2012 (4F059B40)
AtihdW76.sys           Thu Feb 23 07:30:12 2012 (4F463154)
AODDriver2.sys         Tue Mar  6 04:55:00 2012 (4F55DEF4)
MpFilter.sys           Fri Mar  9 06:05:26 2012 (4F59E3F6)
atikmpag.sys           Mon Jun 11 12:26:14 2012 (4FD61C26)
atikmdag.sys           Mon Jun 11 12:59:31 2012 (4FD623F3)
GVTDrv64.sys           Tue Sep  5 03:10:02 2006 (44FD22CA)
gdrv.sys               Thu Mar 12 23:22:29 2009 (49B9D175)
VBoxNetFlt.sys         Tue May 22 08:25:37 2012 (4FBB85C1)
VBoxDrv.sys            Tue May 22 08:25:38 2012 (4FBB85C2)
VBoxUSBMon.sys         Tue May 22 08:25:39 2012 (4FBB85C3)
VBoxNetAdp.sys         Tue May 22 08:25:39 2012 (4FBB85C3)
avgidsdrivera.sys      Fri Dec 23 07:05:21 2011 (4EF46E81)
avgidsfiltera.sys      Fri Dec 23 07:05:40 2011 (4EF46E94)
avgrkx64.sys           Mon Jan 30 22:11:41 2012 (4F275BED)
avgtdia.sys            Sun Mar 18 23:53:32 2012 (4F66ADBC)
avgidsha.sys           Wed Apr 18 22:19:15 2012 (4F8F7623)
avgmfx64.sys           Fri Dec 23 07:08:12 2011 (4EF46F2C)
avgldx64.sys           Tue Feb 21 22:57:53 2012 (4F4467C1)
[/FONT]
mcupdate.dll - Has not been added to the DRT (Driver Reference Table) yet. Search with Google/Bing or post back for further assistance.
NetgearUDSTcpBus.sys- Has not been added to the DRT (Driver Reference Table) yet. Search with Google/Bing or post back for further assistance.
NetgearUDSMBus.sys- Has not been added to the DRT (Driver Reference Table) yet. Search with Google/Bing or post back for further assistance.
Recommendations:
Remove/Uninstal:
Gigabyte Easy Tune 6 driver (known issues w/Win7)
Remove/Uninstal:
Gigabyte Easy Saver - mobo power utility driver
Remove/Uninstal:
Gigabyte on/off charge driver. See here for details - Link Removed May cause BSOD's on Win7 systems - uninstal to test
Remove/Uninstal (remove using the following instructions):
AMD Overdrive; also in EasyTune6 for Gigabyte motherboard
AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Win7 systems.
Please uninstal all AMD/ATI video stuff from Control Panel...Programs...Uninstal a program
Then, download (but DO NOT instal) a fresh copy of the ATI drivers from Link Removed - Invalid URL (in the upper right corner of the page)
Use this procedure to instal the DRIVER ONLY: Link Removed
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Uninstal". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
Uninstal the software/drivers for this device and physically remove it from your system:
Use either a PCI/PCIe wireless card that plugs into your motherboard - or a very long ethernet cable to continue accessing the internet.
The information you've provided contains details about concerns related to both hardware and software on your system. Here's a breakdown based on the categories you've outlined:
Age of System:​
  • Age: Unknown
    Device Concerns:​
  • NETGEAR WNDA4100 N900 Wireless Dual Band USB Adapter:
    • Wireless USB devices, especially in Windows 7 systems, have known issues.
    • Using Vista drivers with these devices can lead to BSODs.
    • It's recommended to switch to an installable wireless PCI/PCIe card for better reliability.
      Software Concerns:​
    []AMD OverDrive, Gigabyte Easy Tune 6 (ET6), Gigabyte Easy Saver, Gigabyte Apple Charger:
    • Known to cause BSODs in Windows 7 systems.
    • Temporary...
Age of System:​
  • Age: Unknown
    Device Concerns:​
      Software Concerns:​
    • Temporary removal of these utilities can help stabilize your system.
      Analysis:​
    ]Memory dump analysis indicates issues like memory corruption, with specific bug check codes and probable causes highlighted.
    3rd Party Drivers:​
    • Specific drivers have been flagged with recommendations for removal or update due to potential issues.
    • Detailed information on each driver's impact is provided, with red-highlighted drivers necessitating immediate action.
    Recommendations:​
    • Removal/uninstallation of drivers like GVTDrv64.sys, gdrv.sys, AppleCharger.sys, AODDriver2.sys is advised.
    • Instructions for safely removing problematic drivers like AODDriver2.sys are provided.
    • Cease overclocking, ensure the system runs at stock values during troubleshooting.
    • Uninstall the software/drivers for NETGEAR WNDA4100 N900 Wireless Dual Band USB Adapter.
    By addressing these hardware and software concerns, you can work towards stabilizing your system and resolving any BSOD issues you may be experiencing. If you need further assistance or have any specific questions related to these recommendations, feel free to ask for help!
