Windows 11 Theme with 8 Photos Won't Cycle
hawkeye62
I have a Microsoft winter theme with 16 photos installed. I can't get the photos to cycle. I have the cycle time at 1 minute. Any help will be appreciated.
Regards, Jim
meharg
If the Photos app is not set as a default photo viewer the scrolling function may not work as the app is not set to view all the photos. Try setting the Photos app as default and check for any improvements.
hawkeye62
Not sure what you mean by "Try setting the Photos app as default...." . Apps > Default apps > Photos has a list of many, many file types listed.
Regards, Jim
hawkeye62
OK, my bad. I had the option about running slide show when on battery set wrong. Everything is working perfectly now.
Regards, Jim
