VIDEO TinyDuino WiFi TinyShield Tutorial (Model ASD2121)
Josephur
Windows Forum Admin
Tutorial Video that I just created.
Like and Subscribe please, it helps me more than you know!
TinyDuino WiFi TinyShield Tutorial (Model ASD2121) In this engaging tutorial video, Joseph Stackhouse from Stack Tech delves into the TinyDuino WiFi TinyShield, a compact yet powerful module for expanding the capabilities of the TinyDuino platform. The video outlines the hardware specifications and demonstrates how to get the TinyShield up and running. Overview of the TinyDuino WiFi TinyShield The TinyDuino is a modular Arduino-compatible platform. The WiFi TinyShield, specifically utilizing the Texas Instruments CC3000 chipset, supports WiFi standards 802.11b and 802.11g, making it suitable for a range of Internet-connected projects. It manages up to four concurrent connections and provides various authentication types including WEP, WPA, and WPA2. However, it's important to note that it does not function as an access point. Power Consumption and Size Power consumption is relatively low in shutdown mode (approximately 5 microamps), but in active mode, it can draw around 275 milliamps, so appropriate power supply considerations are essential. The shield itself boasts a compact size, similar to a thumb, making it ideal for projects with space constraints. Getting Started with the Tutorial Joseph guides viewers through setting up the TinyShield using the Arduino IDE and the required Adafruit CC3000 library. He emphasizes the importance of correctly defining pin settings in the library to ensure communication with the TinyShield. The project's primary task—retrieving the current UNIX timestamp—is presented as a straightforward application to familiarize users with WiFi connectivity. Programming and Project Insights He leads viewers to the TinyCircuits website for additional resources and insights into the CC3000 library. The hands-on demonstration walks through installing the library, configuring it for project-specific settings, and uploading the code. This process highlights not only the simple integration of the WiFi module but also its potential for various applications, from IoT devices to GPS tracking. Community Engagement Joseph encourages viewer interaction by inviting questions and comments, fostering a sense of community among makers and hobbyists. The video closes with a teaser about an upcoming tutorial that will explore the Tiny GPS shield. Conclusion This tutorial is not just an introduction to the TinyDuino WiFi TinyShield; it’s an invitation to explore, experiment, and engage with the possibilities of small-scale IoT projects. For WindowsForum users interested in DIY electronics, this video may ignite inspiration for your next project. Feel free to share your experiences or thoughts on using the TinyDuino or similar microcontroller projects in the comments below! Have you tried integrating WiFi capabilities into your Arduino projects? What challenges did you face? Let's discuss!
