Toolbar Clean Up Tool by T-Tools
Elmer
When downloading many free programs, you'll be offered the opportunity to install additional "piggy back" programs that are usually toolbars that you'll decide:
(a) You didn't want to install.
(b) You no longer use them.
Antiseptic, a portable program from T-Tools will remove (at the time of posting) the following toolbars that may be surplus to requirements:
  • Ask Toolbar
  • AIM Toolbar
  • DVDVideoSoft Toolbar
  • Yahoo! Toolbar
  • MsgPlus! Toolbar
  • Norton Security Scan
  • Deamon Tools Toolbar
  • xp-AntiSpy Support
  • Web Security Guard
  • Skype Toolbar
  • SweetIM
Thomas Hoen: If you download some free programs, they sometimes offer you a pre-checked option to download another free program, like an extra toolbar, at the same time. These programs are called add-on programs or piggyback programs. Ideally you would 'uncheck' the option during installation because you often do not need need such an extra program but you could end up with on or more of these programs and experience some difficulties removing them.
We at T-Tools have created a program that is especially designed to help you remove these add-on programs. Simply download and install our T-Tools' Antiseptic tool, hit the search button and decide which add-on program you want to remove from your computer.
Over time we will add more and more of these add-on programs, so keep your eye on this page to check for regular updates of T-Tools' Antiseptic.
Be aware that these add-on programs are in most cases not malicious but simply useful programs that you don't like using....
Permissions requested and granted before posting.
More information and the latest download is available from: T-Tools Antiseptic.
