Ultimate Ears, a subsidiary of Logitech, has recently expanded its lineup of portable Bluetooth speakers with the introduction of the EVERBOOM. This new model aims to deliver a premium 360-degree sound experience, combining robust durability with high-quality audio performance. Alongside the EVERBOOM, the company has updated its existing models—WONDERBOOM 4, BOOM 4, and MEGABOOM 4—incorporating enhanced acoustics, new color options, and materials sourced from sustainable origins. Jonah Staw, General Manager of Ultimate Ears, emphasized the brand's commitment to meeting user demands for reliable sound quality in portable speakers.
A portable black wireless speaker placed outdoors near a pool with greenery in the background.Design and Build Quality​
The EVERBOOM features an elliptical cylindrical design, measuring approximately 8 inches (200 mm) in height, 4.3 inches (110 mm) in width, and 3.25 inches (85 mm) in depth. Weighing around 2.1 pounds (960 grams), it strikes a balance between portability and substantial build quality. The speaker is wrapped in a durable fabric mesh, with rubberized silicone on the top and bottom, enhancing its resilience against drops and scrapes. Notably, the EVERBOOM carries an IP67 rating, indicating it is both dustproof and waterproof, capable of withstanding submersion in water up to 1 meter for 30 minutes. Additionally, it is designed to float, making it suitable for poolside use. A built-in carabiner clip adds convenience for on-the-go users, allowing the speaker to be attached to backpacks or other gear.
Audio Performance​
Equipped with two 56.6 x 56.2 mm active full-range transducers and two 49.4 x 87 mm passive radiators, the EVERBOOM delivers a 360-degree soundstage. This design ensures consistent audio reproduction from most angles, making it ideal for group settings. The speaker can reach a maximum volume of 90 dBC, with an Outdoor Boost mode that increases it to 91 dBC, enhancing its performance in open environments. While the mid-range frequencies are well-balanced, ensuring clear vocals and lead instruments, the treble range may lack some clarity, and the bass, though present, might not satisfy those seeking deep low-end performance. At higher volumes, some distortion can occur, particularly in bass-heavy tracks.
Features and Connectivity​
The EVERBOOM offers a suite of features aimed at enhancing user experience:
  • Battery Life: Up to 20 hours of playback on a single charge, with actual performance varying based on usage and volume levels.
  • Bluetooth Connectivity: Utilizes Bluetooth 5.3, providing a wireless range of up to 55 meters (180 feet). However, it lacks multi-device connectivity, limiting simultaneous connections.
  • Companion App: The Ultimate Ears Boom app allows users to customize the sound profile through a graphic equalizer and presets. It also supports PartyUp, enabling pairing with multiple compatible Ultimate Ears speakers for synchronized playback. A Megaphone feature lets users broadcast their voice through the speaker via the app.
  • Outdoor Boost Mode: Tailors the audio output for outdoor environments by emphasizing frequencies that travel well in open spaces.
  • NFC Pairing: Facilitates quick pairing with NFC-compatible Android devices by tapping the device to the top of the speaker. This feature is not currently supported on iOS devices.
Notably, the EVERBOOM lacks a 3.5mm auxiliary input and does not support Wi-Fi connectivity, focusing solely on Bluetooth for wireless audio streaming. It also does not include built-in microphones, precluding speakerphone functionality.
Market Position and Pricing​
Launched in June 2024, the EVERBOOM is priced at $249.99 in the United States, £249.99 in the United Kingdom, and AU$349 in Australia. This positions it between the MEGABOOM series and the higher-end EPICBOOM model within Ultimate Ears' product lineup. The speaker is available in multiple color options, including Charcoal Black, Azure Blue, Raspberry Red, and Enchanting Lilac.
Critical Reception​
The EVERBOOM has received mixed reviews from critics:
  • TechRadar praised its durability and sound quality, noting its suitability for outdoor use and its ability to deliver loud, room-filling audio. However, they mentioned that at maximum volume, some distortion is present, and the speaker lacks Wi-Fi connectivity and a 3.5mm port.
  • SoundGuys highlighted the speaker's omnidirectional sound and robust build but questioned its value proposition, noting similarities with the existing, less expensive MEGABOOM series. They also pointed out that the midrange can sound slightly muffled in close quarters.
  • What Hi-Fi? commended the EVERBOOM's bold and powerful sound in a durable package but criticized its lack of sonic detail and refinement, suggesting that discerning listeners might find it lacking compared to competitors.
The Ultimate Ears EVERBOOM stands out as a durable and feature-rich portable Bluetooth speaker, well-suited for outdoor enthusiasts and those seeking a robust audio companion for various adventures. Its 360-degree sound projection, substantial battery life, and rugged design make it a compelling choice for users prioritizing these attributes. However, its higher price point, absence of certain connectivity options, and some audio performance limitations at higher volumes may lead potential buyers to consider alternative options within the competitive portable speaker market.
Source: BetaNews BetaNews
