CharlieJeffy
Hi, I just installed a copy of Windows 7 Ultimate, 32 bit version. I Immediately got Marvell Yukon 32-bit Windows 7 drivers, so I could connect to the internet. Unfortunately, I didn't copy the IP address and all that, so I went on my sister's laptop and got it from there. Everything worked fine, the IP was good, no errors. However, after actually saving the configuration, it gave me "Unidentified Network". I use broadband to connect to the internet, by the way, but I need the LAN configuration, so it works. Well, I can't figure out what to do. I tried reinstalling, updating drivers, rebooting, shutting down, nothing works. I can't even ipconfig/release and ipconfig/renew, because it says:
Windows IP Configuration
The operation failed as no adapter is in the state permissible for this operation.
What should I do?
IP Config@All
C:\Users\Charlie>ipconfig/all
Host Name . . . . . . . . . . . . : Home
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
PPP adapter DIGI:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : DIGI
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 172.17.113.171(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 0.0.0.0
DNS Servers . . . . . . . . . . . : 193.231.236.30
193.231.236.25
Primary WINS Server . . . . . . . : 10.11.12.13
Secondary WINS Server . . . . . . : 10.11.12.14
NetBIOS over Tcpip. . . . . . . . : Disabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Marvell Yukon 88E8001/8003/8010 PCI Gigab
it Ethernet Controller
Physical Address. . . . . . . . . : 00-1A-4D-64-2B-F4
Link-local IPv6 Address . . . . . : fe80::20fa:5fd4:c8e7:cdd3%15(Preferred)
IPv4 Address. . . . . . . . . . . : 82.76.25.181(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 82.76.25.1
DHCPv6 IAID . . . . . . . . . . . : 251664973
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-70-60-7B-00-1A-4D-64-2B-F4
DNS Servers . . . . . . . . . . . : 193.231.236.25
193.231.236.30
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{37FED621-2950-470D-966F-103A7F3B8E5F}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter 6TO4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
IPv6 Address. . . . . . . . . . . : 2002:524c:19b5::524c:19b5(Preferred)
Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
193.231.236.30
Tunnel adapter isatap.{B86EFB41-8AAA-4130-9923-F155CA70842F}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
C:\Users\Charlie>
What are your system specs...as detailed as you can please.
Intel Core 2 Duo [email protected] GHZ, 2 GB ram, GT430 Dual-Fan 1GB, 200 SATA disk, 32-bit Windows 7. Dunno what else to say.
Edit, got this from another forum.
Hi, Welcome to Seven Forums
You can't use IPCONFIG /release and /renew because your Yukon ethernet connection is not using DHCP.
Is your router that you are connecting to set up for DHCP?
Write the addresses down, then go into Network and sharing centre and change the connection settings to use DHCP (Automatically obtain IP address, and the bottom one Automatically obtain DNS server addresses).
What is the PPP DIGI adapter used for? Do you use your computer in multiple...
What is the PPP DIGI adapter used for? Do you use your computer in multiple locations?
, so nevermind that ipconfig/release, ipconfig/renew part.
