Windows 7 USB External Hard Drive Detected But Not In Explorer
Ambaldan
I have a Seagate SATA 1TB HD I pulled functional from a Windows 7 system. When I connected it to my Toshiba Laptop with a SATA to USB adapter, also running Windows 7, the drivers installed, but no drive in Explorer. The device shows in Devices and Printers as "External", and Properties says the device is operating properly. Drive Manager shows the drive as present but Invalid. I ran Seagate's SeaTools diagnostics, and it could access the drive just fine, all tests passed. A smaller 160GB Seagate HD on the same adapter connects and reads just fine. Any suggestions to resove this would be fantastic, I really need the files off this drive!
Where it shows in disk management does it have a letter assigned and is it online? If it's offline go down to the bar and on the left side it will say Disk 1 right click there and put it online.
Joe
In the disk manager does the drive have a letter and is it online?
Joe
Drive shows in Disk Manager as type Dynamic, and status of Invalid, with no drive letter. Right-click => Reactivate brings the error message "The operation is not allowed on the invalid disk pack."
I've got a very similar problem to Ambaldan, and looking through this forum it seems we're not alone having issues with external HDDs in Windows 7.
I'm using Window 7 64bit, on my brand new Toshiba laptop. I have tried to connect my LaCie 250GB hard drive but it fails to appear in the list of drives in the "Computer" section.
So far I have checked the following
1) that it works on another PC, which it does without any issues, although this was Vista not Win 7
2) that it appears in the device manager, which it does. No driver issues or the like are indicated
3) In diskmgmt.msc, the device appears as "Disk 1; Basic; 230GB; Online" in the bottom portion of the Disk Management window, however it does NOT appear in the list of drives in the top portion of the window.
When I tried to assign a drive letter to the external HDD, an error message stating that the console view has not been refreshed occurred, and is not sorted out by refreshing the view, nor by restarting the computer.
Any ideas?
-Will
Joe
Hi Joe,
Yes, it is listed as online. This is what my disk management screen looks like when I try to assign a drive letter. Refreshing the console and restarting the computer don't solve the problem.
The drive in question is Disk 2 in this screenshot.
