USB Mouse
I have a HP G60-115EM Laptop and i have a usb mouse and keyboard made by hd. I like to use them sometimes. But when i plug the usb device in for the wireless i get a message saying "HID Data has stopped working" then the mouse will not work but the keyboard will... Why?
But the strange thing is. I have 3 usb ports on my laptop. One on the left and two on the right. If i plug the usb adapter in the left the hid data stops working but if i plug it in the 1st one on the right it doesn't and works ok???
Why is this?
Windows Forum Admin
Not entirely sure but pc's can be the same. If a device fails to work properly in say the front USB ports then you always try the ones at the back Does your mouse come with a driver? You could always check if there's an update if it does..
On the question of USB ports and why some seem to differ I did in fact try to google for an answer but the nearest I got was this..
Difference between front-panel and rear-panel USB ports - Hardware - HP Support Forums
Celestra
Former Moderator
I have a HP G60-115EM Laptop and i have a usb mouse and keyboard made by hd. I like to use them sometimes. But when i plug the usb device in for the wireless i get a message saying \"HID Data has stopped working\" then the mouse will not work but the keyboard will... Why?
Why is this?
Do you have a Microsoft Bluetooth Mouse 5000? HP has something wrong with the "HP Quick Play Buttons" Here read these two articles: PC Magazine Discussions - HID DATA has stopped working message (these below might have a better solution)
http://forums.techarena.in/vista-hardware-devices/1023595.htm
I don't know the model. They just came with a desktop computer my dad got a few years ago.
Ill try uploading a picture to show you. All i know is that it is hp make.
Also i don't know about driver. It works with plug 'n' play. I just plug it in. It loads a driver or something then i get a HID Data message.
Then i just plug it in and get the message any other time.
Oh and also. I have 3 usb ports. 1 on the left. 2 on the right. But it only works on the one on the right closest to my screen. The one next to it dosent work.
Here are some pics:
Mouse from front:
Mouse from back:
Adapter to recieve mouse signal front:
Back of mouse adapter:
By the way im on vista. Im just using a mac theme.
Here are the other pictures i could not get in the other post:
USB Port plugged in:
Laptop:
HID Message:
Celestra
Former Moderator
Hi! his is what HP says about that error: I think I'm right... (Can't always remove documents from HP Library, sorry about thumbnails)
Windows Forum Admin
#7
The only thing I would do in this instance is check HP's website for any updates. I'd also use this utility found here:
http://www.lavalys.com/products.php?ps=UE&lang=en&page=1
It's called Everest. It is a benchmarking and system information tool which also has a free version... You could give it a run and see what it say's...
