Windows 7 Very Irritating Problem
DriversMeCrazy
Hello I have tried all suggestions on the web to fix this I think, and it still won't work. My DNS servers are not responding and I have been unable to find a fix. I have tried flushing, registering, releasing, renewing and so on. Many of these are not effective. Here is what comes up when i typed ipconfig /all -
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Owner-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Peer-Peer
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : hsd1.ma.comcast.net.
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : hsd1.ma.comcast.net.
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 78-2B-CB-D0-F6-03
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2601:6:2880:431:417a:2bfe:af9d:6a5c(Prefe
rred)
Temporary IPv6 Address. . . . . . : 2601:6:2880:431:ac42:ba08:5a65:433a(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::417a:2bfe:af9d:6a5c%15(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.0.28(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, May 23, 2014 12:50:37 AM
Lease Expires . . . . . . . . . . : Friday, May 30, 2014 12:50:36 AM
Default Gateway . . . . . . . . . : fe80::21d:d4ff:fe5f:85f1%15
10.0.0.1
DHCP Server . . . . . . . . . . . : 10.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 561523659
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-16-BC-C1-12-BC-77-37-44-EE-90
DNS Servers . . . . . . . . . . . : 2001:558:feed::1
2001:558:feed::2
75.75.75.75
75.75.76.76
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wireless Network Connection 3:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter #
2
Physical Address. . . . . . . . . : BC-77-37-44-EE-91
Wireless LAN adapter Wireless Network Connection 2:
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 1030
Physical Address. . . . . . . . . : BC-77-37-44-EE-90
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : BC-77-37-44-EE-94
Tunnel adapter isatap.hsd1.ma.comcast.net.:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:90d7:14d2:2b47:b4bb:f298(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::14d2:2b47:b4bb:f298%16(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
Any help is much appreciated, thank you all for considering.
Trouble
Noob Whisperer
You might try setting your DNS server addresses manually and see if that help.
Click Start and type
ncpa.cpl into the search box and hit enter
In the resultant Network Connections windows select then right click the adapter that you are using (you may want to disable any that you are not using) and choose properties.
In the resultant adapter properties dialog box uncheck Internet Protocol Version 6
Select (highlight) Internet Protocol Version 4 and click the properties button
In the resultant IPv4 properties dialog box select the radio button that says "Use the following DNS server addresses:"
Typically Comcast will use
Preferred DNS server: 75.75.75.75
Alternate DNS server: 75.75.76.76
DriversMeCrazy
Hello thank you for the response, but it seems to have not solved my problem. Any other ideas? Thanks
Trouble
Noob Whisperer
Uninstall it, at least temporarily.
Use the programs and features applet in the control panel to uninstall and then follow up with the vendor specific proprietary removal tool McAfee Consumer Product Removal (MCPR.exe for short) found here http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe
Reboot your computer.
Install Microsoft Security Essentials from here Link Removed
Keep us posted.
DriversMeCrazy
Keep us posted.
Hello again thank you for the response, but the problem is persisting!!
Trouble
Noob Whisperer
Hold the Windows Logo Key and strike the R key and type
ncpa.cpl
in the resultant network connections window select then right click the network adapter you are using and choose properties.
In the resultant Ethernet Properties dialog box in the section labeled "This connection uses the following items:"
Look for anything associated with any security suites or anti virus product either installed presently or perhaps previously installed and removed.
It should basically have
Client for Microsoft Networks checked
File and Printer Sharing for Microsoft Networks checked
QoS Packet Scheduler checked
Microsoft LLDP Protocol Driver checked
Link Layer Topology Discovery Mapper I/O Driver checked
Link Layer Topology Dicovery Responder checked
Internet Protocol Version 4 (TCP/IPv4) checked
nothing else.
DriversMeCrazy
ncpa.cpl
nothing else.
Thank you for the timely response, but I do already do have all above checked and did not see anything to do with security. Thank you
Trouble
Noob Whisperer
Try setting you DNS server manually to
Preferred 10.0.0.1
Alternate 75.75.75.75
Trouble
Noob Whisperer
reset the winsock catalog and the tcp/ip stack
from an elevated command prompt type
netsh winsock reset
hit enter
type
netsh int ip reset resetlog.txt
hit enter
reboot
badrobot
Have you done something about the hardware? Like hard reset on the modem?
DriversMeCrazy
netsh winsock reset
hit enter
type
hit enter
reboot
Thanks this actually made it work really well for about 10 minutes and now im back to where I was !
Yes multiple times
badrobot
It seems that you've tried everything and nothing seems to work. Maybe you have a defective network adapter. Try one of those USB adapters. If it still doesn't work, you can always return them.
Here's one cheap one that works well if you can find it in your area. One thing I like about this one is the fact that it is a dual band:
http://www.canadacomputers.com/product_info.php?cPath=27_1232&item_id=062513
