duderinoman
- Joined
- Jan 5, 2018
- Messages
- 12
- Thread Author
- #1
What do i do after that?Does the new mouse come with a software suite or is it just a normal run of the mill mouse? If so you can still make some changes by opening the Control panel followed by Hardware and Sound then under Devices and printers click mouse.
My next question was going to be what was the name of the mouse.Microsoft wireless mouse
The mouse is brand new. I'll still check it though Im using it on a mousepad a clean mouse padCan you check the sensor on the bottom of the mouse (were the light is) for any debris such as hair. That can confuse the tracking and cause the mouse to jump erratically on screen. Also using the mouse on a solid colored surface can screw up the tracking.
same thingTest it on a different PC with a different pad. What shows up than?
