Windows 7 When my PC is on, laptops/PS3 can no longer connect to wireless
Emhyr var Emrei
Hello,
My roommate and I have noticed that whenever my PC is turned on, nothing else can connect to our wireless -- our phones, laptops, and the PS3 simply won't connect. When we turn it off, all of those can be connected at the same time, but the second windows 7 begins, they'll all lose connection.
Anyone have a similar experience? I'm clueless on where to even begin.
Goto programs, command prompt and execute the command:
ipconfig /all
Post the output on here and we can see if you are suffering any IP conflicts.
ipconfig /all
ipconfig /all
Here are the results
my ip config results said:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Justin PC>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : JustinPC-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 90-2B-34-A8-4C-C8
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::284d:c6fa:45f:3000%13(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.4(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, January 14, 2013 2:38:14 AM
Lease Expires . . . . . . . . . . : Monday, January 14, 2013 3:38:13 AM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 277883700
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-5E-12-93-90-2B-34-A8-4C-C8
DNS Servers . . . . . . . . . . . : 209.18.47.61
209.18.47.62
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{F3CD48C2-2D30-4DD0-9BA6-43555F8A49FC}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:28fb:94b:3f57:fffb(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::28fb:94b:3f57:fffb%11(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
C:\Users\Justin PC>
