MIRKOSOFT
Active Member
Hi!
I know where to find all Win32 settings and corresponding registry entries.
Since Windows 8 I found some problems with modern UI (or Metro) applications with their path and even have no idea how and where are settings stored.
So, where are located Windows 10 Applications settings - I want to modify some and maybe transfer settings to another account?
And also how are stored and its structure/format?
Thank you for each help, reply or comment.
Miro
JandN2639
Well-Known Member
Please clarify. Which applications do you mean? Many apps are found in the two Programs folders in the main drive.
Sent from my iPhone using Tapatalk
MIRKOSOFT
Active Member
Ok, here they're:
Panels
Taskbar Gadget
Sense Desktop
Traditional Start Menu
But it is list which I need. Better is to know how are settins stored, where and settings structure.
Windows has two main types of applications: Win32 and Metro.
Miro
