Windows 10 Which Window is Better Window 10 or Window 7?
girishf1
Hii Guys, I had just formatted pc and I wanted to Know is windows 10 better or window 7. For my PC because I used to have windows 7 on my pc for my business use.
Thanks & Regards.
Since win 7 is no longer supported it makes it a target for virus and malware! If you never go on line or install new software you most likely would be safe. Otherwise go for win 10, close enough that you will be fine, unless you have some old program that will not run.
