Rapaaja
Active Member
HI
1Questions wonders: that is, the question is why when Windows 10 Task Manager when you look at the RAM memory speeds so far it will appear 1200Mhz even though the memory speed is 2400Mhz. However, in bios, everything is displayed correctly, in terms of volume and speed. Memory is 8Gt DDR4 2400Mhz. reinstalling fixed the situation but after a while the situation came back: - /
Udates 1903
nmsuk
1200 is correct as it's ddr so 2x1200 mine shows as 1600 and I have 3200 ram. So this is nothing to worry about
38210
Rapaaja
Active Member
Sorry wy difrens? yuo hawe 2 / 1200 :;2400 is real :? are that expaniols or tru sorry lanques . thanks. SOLVET,
nmsuk
Well 1600 in my case is the frequency which is the way microsoft report it. Bios and memory makers just label it in MT and not Mhz
Rapaaja
Active Member
Thank you, I understood the idea of Thank you so to show your frequency THANK YOU. rapaaja
