I recieve a PROCESS1_INITIALIZATION_FAILURE. I am experienced in computer truobleshooting with the exception of Blue Screens. Thus, this is my first post in ANY windows troubleshooting forum. I am looking for ANY help so please read all of this since I don't really know what information is critical so I am getting detailed.
I was trying to get Halo 2 for Vista to work on Windows 7 x64 Ult custom build (By trying the following: Halo 2 Windows 7 (workaround) - "System Cannot Find the Path Specified" or "LIVE gaming on Windows failed to initialize" - Games for Windows Live ).
I also unistalled an unrecognized USB driver from device manager.
After that failed to fix my Halo 2 problem I updated my GPU card driver and rebooted my PC.
*ENTER BSOD*
After "Starting Windows" screen appears for roughly ten seconds a "PROCESS1_INITIALIZATION_FAILURE" BS appears. The computer reboots (after about 1.5 seconds) after the Memory Dump reaches 100. I do not get any option to boot into safemode or with "Last known working configuration" but I DO get the options to either start the start-up repair or reboot windows normally.
If I reboot normally the problem repeats, trapping me in a boot loop. So I launch start-up repair.
I tried "Startup Repair" as well as System Restore (I tried ALL of my restore points) but get an error telling me "Windows cannot repair this computer automattically" or "System restore was not successful", respectivaly. I can then choose to send information about this problem or not but I get no further troubleshooting options.
FORTUNATLY, I was able to boot to desktop AFTER using the command prompt to xcopy a "bootcat.cache" file from my HP Laptop (Also running 7 x64 Ult.) into my build's \system32\CodeIntegrity folder in:
- C:\ (The DISKPART > "list volume" command says this is a 100MB system reserve partition of my main HDD)
- D:\ (actual 931GB partition of my main HDD that is my Local Disk [I do not know why it is D:\ and not C:\ but before this it was E:\ and my CD-ROM drive was D:\ so it gets reassigned each time I reboot. [I have even tried the DISKPART > "assign letter=C" command to reassign letter C to this drive but it doesn't seem to help or hurt anything since my Local disk was not C in startup repair but is back to C: now that i have booted]). And
- X:\ (I do not know what this is but it was the default drive when I entered the command prompt [I believe the default was X:\sources or something like that]). I exit command prompt and reboot.
*I AM NOW ABLE TO BOOT TEMPERARILY*
Then and ONLY then will the computer boot to my desktop. A few drivers, such as my GPU driver must be reistalled (I assume this because these drivers were not on my HP's bootcat.cache?).
So besides some missing/inactive drivers I have full function of my PC. BUT WHEN I REBOOT THE PROBLEM COMES BACK AND I B.S. AGAIN. So I performed my fix again and booted to my desktop once more. I have now started backing up my files in preparation an imminent clean install (I am willing to try ANYTHING to avoid this!). While files are backing up I am saving Application and System event logs. (PM me for the logs). Running and screen-shotting CPU-Z and posting this thread.
I do not know what I should try now that I am back at my desktop. ANY help at all will make my day.
Thank you all!
View attachment 012511-37440-01.dmp
View attachment 021511-40061-01.dmp
View attachment 021611-21949-01.dmp
View attachment 012911-38766-01.dmp
*ENTER BSOD*
Thank you all!
