garyl
Sigh, I guess I will start from downloading IOBIT advanced system care and then it asked me to update my driver and now I have this driver failure thing where I'm unable to login to window, I've googled so much and now I'm in need of the rescue disc file for rebooting so I can perform system restoration, but I'm unable to download it from the window official website because I don't have the registration key... it was installed for me at the shop so I never had a disc.
I've actually downloaded the disc else where and installed it onto a USB but it didn't seem to detect the USB at all, I did perform F2 , boot mode and put all my USB drives to the top as my priority, I don't know if the files were corrupted at the beginning so now I'm hoping if someone can help...
Many thanks
Try the following
  • Boot into safemode
  • The driver should not be loaded so you can login
  • Open an elevated command prompt
  • Type pnputil -e
  • Look for the driver for IOBIT and make note of the OEM##.inf
  • Type pnputil -f -d OEM##.inf
  • That should remove the driver from your system
  • Reboot and try logging in again
Neemobeer
Windows Forum Team
Try the following
  • Type pnputil -e
