Windows 11 Insider: speed test, search counts, dark Folder Options, Bluetooth LE audio, Paint AI
Microsoft’s latest Insider flight delivers a concentrated burst of polish and experimentation: a built‑in network speed test in the taskbar, a long‑requested dark theme fix for File Explorer’s Folder Options, per‑listener volume controls for Bluetooth LE shared audio, and a security‑focused change that locks batch files while they run — plus a parallel wave of AI and usability updates to the Paint app that point toward Microsoft’s long game for legacy apps and creative tooling.
Windows desktop showing dark Folder Options, Paint, and a Bluetooth/audio panel over a blue wallpaper.Background​
Microsoft is juggling two connected priorities: modernizing core Windows 11 experiences while updating long‑standing inbox apps to reflect current expectations around AI, accessibility, and system security. Over the last few Insider builds released across Canary, Dev, and Beta channels, the company has been rolling out a mix of consumer‑facing conveniences and administrative controls. These updates are shipping to Insiders first — which means they are preview code, not general‑availability releases — but they reveal where Microsoft is headed for the next feature waves of Windows 11.
This feature set falls into three categories:
  • Surface‑level productivity and UX tweaks (taskbar speed test, exact search counts, Folder Options dark theme).
  • Media and collaboration improvements (Bluetooth LE shared audio with independent sliders).
  • Platform and security changes for administrators and power users (batch file locking and signature‑validation optimizations).
At the same time, Microsoft’s Paint app has continued its transformation from a nostalgic utility to a modern creative tool with AI‑assisted features and workflow improvements. Taken together, the changes show a company balancing polish and experimental capabilities, while trying to avoid breaking legacy workflows.
What changed in the taskbar and system tray​
Built‑in network speed test: convenience meets diagnostics​
Windows Insiders are now seeing a built‑in network speed test accessible directly from the taskbar’s network icon and quick settings. The test launches in the default browser and measures Ethernet, Wi‑Fi, and cellular performance, making it possible to run a quick connectivity check without opening a third‑party tool.
Why this matters:
  • It lowers the friction for basic troubleshooting — helpful for both end users and helpdesk staff.
  • Displaying the test from the system tray positions connectivity diagnostics as part of the everyday desktop experience rather than a hidden admin tool.
Practical considerations:
  • Because the test opens in the default browser, results and the UX will depend somewhat on the browser implementation and how Microsoft integrates the back end that performs the measurements.
  • This is a lightweight, on‑demand check — not a substitute for enterprise network diagnostics or historical telemetry.
Taskbar search now shows exact result counts​
A small but meaningful change: taskbar search indicators now display exact result counts instead of approximate ballpark numbers. For users who rely on taskbar search to find documents or settings, the change reduces guesswork and improves confidence.
User impact:
  • Faster triage for search results (you’ll know immediately whether dozens or hundreds of results were found).
  • Slightly better predictability when combining local Indexing and cloud‑backed results.
File Explorer and visual consistency​
Folder Options finally respects the system dark theme​
Folder Options, a notoriously overlooked dialog, now matches the system's dark theme. Beyond aesthetics, this change is a quality‑of‑life improvement for dark‑mode users who have long experienced jarring theme breaks in legacy dialogs.
Why this is important:
  • It’s emblematic of Microsoft’s broader push to finish the job on system UI consistency.
  • It reduces visual fatigue and improves the sense of polish across Windows components.
Implementation note:
  • This is largely a UI change; it does not alter Folder Options functionality. Administrators should still validate policy‑driven UI behaviors (such as Group Policy or MDM‑enforced Folder Options) before assuming parity across environments.
Shared audio and Bluetooth LE Audio: individualized control​
Two headsets, two volumes​
Windows 11’s shared audio preview — built on Bluetooth LE Audio — now features per‑listener volume sliders when streaming to two headsets simultaneously. This allows two listeners to share the same audio source while retaining independent loudness control.
Key benefits:
  • Better shared‑listening experiences on planes, in living rooms, or in educational settings.
  • More granular accessibility options (different listeners can set levels appropriate to their hearing needs).
Requirements and caveats:
  • Shared audio requires Bluetooth LE Audio support in both the PC’s Bluetooth stack and the accessory firmware.
  • Microsoft’s rollout has been gated to certain Copilot+ PC models initially; broader hardware support is expected to expand over time.
Real‑world implications:
  • For IT and AV teams, the new capability simplifies playing the same audio stream to two endpoints, but it also adds a new surface for driver and firmware compatibility issues.
  • Expect initial limitations: not all headphones and earbuds will work immediately, and audio synchronization or driver quirks may appear on older hardware.
Paint, reimagined: AI, coloring‑books, and workflow improvements​
Paint’s AI features are no longer an experiment behind closed doors​
Microsoft continues to evolve Paint beyond the “classic” utility. Recent updates — rolling to Insiders and being integrated into mainstream builds — add AI‑driven tools: a Cocreator side panel, Coloring book generation from text prompts, a fill tolerance slider, and refined UX around applying AI outputs to the canvas.
Highlights:
  • Cocreator: a Copilot‑style panel that accepts prompts and produces images or elements which can be applied to the canvas; includes controls like a Creativity slider, Try again and Apply buttons to iterate quickly.
  • Coloring book: generates printable coloring‑page templates from text prompts; a niche but illustrative example of AI integration in an everyday app.
  • Usability tweaks such as streaming previews (in Notepad) and improved Markdown support reflect Microsoft’s broader push to modernize inbox apps.
Accessibility and creative workflows:
  • The new tools democratize creative tasks for users who aren’t familiar with full‑featured editors like Photoshop.
  • For teachers, parents, and casual creators, on‑device generation of coloring pages or simple illustrations is a practical feature.
Limitations:
  • Some AI features are tied to Copilot Plus hardware or services and may require cloud connectivity or specific hardware capabilities.
  • Rights, licensing, and model provenance remain topics where enterprise admins and creative professionals should exercise caution — especially for commercial use of AI‑generated imagery.
Batch file locking: security and performance for scripts​
What changed​
Microsoft introduced a new administrative control that locks batch files while they execute, preventing in‑flight modification. This is implemented via a registry toggle and — in some descriptions — an optional application manifest flag for App Control scenarios.
Why Microsoft did it:
  • Prevents malicious or accidental modification of a script while it’s running.
  • Reduces overhead under code‑integrity enforcement scenarios by validating a script’s signature once, rather than repeatedly for each statement executed.
How administrators can enable it (high‑level):
  • Create a DWORD value under HKEY_LOCAL_MACHINE\Software\Microsoft\Command Processor.
  • Name the value consistent with Microsoft’s guidance (see the notes below on naming confusion) and set it to 1 to enable locking.
Performance and operational benefits:
  • In environments where App Control or code integrity policies are active, repeated signature checks can cause performance degradation. Locking the script file while it runs allows a single validation step, improving predictability.
  • Helps defend against certain attack vectors that rely on altering scripts mid‑execution.
Important caveats and discrepancies:
  • Public reporting shows some inconsistency in the exact registry value name (reports use both LockBatchFilesWhenInUse and LockBatchFilesInUse). This discrepancy is significant for administrators who might apply the wrong key in production.
  • Microsoft’s own documentation, Insiders’ release notes, and community writeups should be consulted before deploying broadly.
Risk surface:
  • Some legacy scripts rely on self‑modifying behavior. Enabling this lock may break those workflows.
  • Interaction with third‑party endpoint security tools is not fully documented; administrators should test in a lab before deploying to production.
Cross‑cutting themes: rollout, hardware support, and Insider channels​
Insider channels and risk profile​
These features are distributed across the Canary, Dev, and Beta Insider channels — each with different risk and stability characteristics:
  • Canary: earliest, most experimental code; expect breakage.
  • Dev: active feature testing; more stable than Canary but not production‑grade.
  • Beta: closer to release candidate quality; better for previewing features headed to mainstream builds.
If you rely on your device for production work, avoid installing Canary builds. IT teams should maintain a lab fleet for testing features like batch file locks and shared audio before broad deployment.
Hardware and driver dependencies​
Several updates — notably Bluetooth LE shared audio and some AI‑driven Paint features — have explicit hardware or firmware dependencies:
  • Bluetooth LE Audio requires compatible Bluetooth chipsets and accessory firmware to get full benefits (Bluetooth 5.2 or later and LE Audio stack support).
  • Some Paint AI features are gated to Copilot‑capable or Copilot+ PCs and may also require cloud services.
IT admins and enthusiasts should confirm driver availability from OEMs and accessory vendors before expecting immediate compatibility.
Security analysis: trade‑offs and mitigation​
Batch file locking is a net security gain — with caveats​
Locking scripts during execution closes an attack vector where malicious installers or updates alter a script in flight. The additional single‑validation model reduces CPU and I/O overhead and improves predictability under policy enforcement.
However:
  • Legacy, intentionally self‑modifying scripts will break when the lock is enabled. Organizations relying on such scripts must refactor them or selectively opt out of the lock.
  • The inconsistent naming of the registry key found in early reporting creates the risk that administrators will enable the wrong setting or apply incomplete mitigations.
Recommendation:
  • Test the registry toggle in a controlled environment.
  • Use application manifests for granular App Control scenarios where possible.
  • Confirm behavior against vendor endpoint protection products to avoid unintended policy conflicts.
Shared audio and privacy​
Streaming audio to multiple devices simultaneously introduces modest new privacy considerations:
  • Make sure users understand when their device is in “shared audio” mode and which devices are connected.
  • Leave visual affordances in place (system icons, notifications) to clearly indicate active streams.
Compatibility and admin guidance​
Best practices for IT teams evaluating or preparing to deploy these features:
  • Establish a test fleet with representative hardware, including Bluetooth accessories and devices with and without Copilot hardware features.
  • Validate the batch‑file lock behavior against existing scripts; refactor self‑modifying scripts or set controlled exceptions where necessary.
  • Confirm driver and firmware availability for Bluetooth LE Audio on vendor portals — do not assume older devices will be updated.
  • Update internal troubleshooting documentation to include the new network speed test as a quick first step.
  • Monitor Windows Insider release notes and official Microsoft posts for corrections — particularly for registry key names or manifest flags.
How to try the features (Insider preview steps)​
If you want to experiment with these updates, follow a conservative approach:
  • Join the Windows Insider Program on a non‑production device.
  • Choose the channel that matches your risk tolerance (Canary for earliest access; Dev for active feature testing; Beta for more stable previews).
  • Apply the latest Insider build and restart as required.
  • Test functionality:
  • Use the system tray network icon to run the built‑in speed test.
  • Open taskbar search to confirm exact result counts appear.
  • Pair two Bluetooth LE Audio devices and use the Shared Audio tile in Quick Settings to try simultaneous playback and volume sliders.
  • Launch Paint and explore the Cocreator panel, Coloring book generator, and fill tolerance slider.
  • If testing batch file locking, perform tests in a VM or isolated environment and verify which registry key enables the feature.
Safety note:
  • Always keep a recovery plan (system image or restore point). Insiders builds can cause unpredictable behavior.
Strengths and notable wins​
  • Microsoft is improving user experience continuity. Fixing the Folder Options theme mismatch and showing exact search counts are small changes with outsized perception value.
  • Tighter integration of diagnostics into daily UX. The system‑tray speed test reduces friction for basic troubleshooting and aligns with Microsoft’s strategy to make diagnostics more discoverable.
  • Progressive modernization of legacy apps. Paint’s evolution shows a thoughtful path from nostalgia to productivity: accessible AI tooling, iteration controls, and print/export workflows that matter to non‑professional creators.
  • Security and performance focus for operational environments. The batch file locking setting is a pragmatic answer to real issues in managed deployments where code integrity and App Control impose execution overhead.
Risks and unknowns​
  • Naming inconsistency for registry keys introduces administrative risk. Early reports show different names used in documentation; until Microsoft clarifies, admins should be cautious.
  • Hardware fragmentation will limit adoption of shared audio and some Paint features. Expect a phased experience based on OEM driver updates and accessory firmware.
  • Insider instability. Canary/Dev builds can regress. Do not deploy Insider builds into production.
  • Unclear timeline for GA. While Insiders get a preview, Microsoft’s schedule for general availability across mainstream Windows 11 channels and enterprise servicing is still subject to change.
Final assessment​
These Insider releases reflect a pragmatic, multi‑layered strategy: Microsoft is addressing day‑to‑day user friction with UI polish and discoverability improvements, while also delivering forward‑looking capabilities like shared Bluetooth LE audio and on‑device creative AI in Paint. The batch file locking change reinforces a security posture that prioritizes predictability and performance under enforcement scenarios — a welcome move for enterprise administrators.
That said, the path from preview to production will require careful stewardship. Hardware dependency on Bluetooth LE Audio, inconsistent registry naming in early reporting, and the usual volatility of Insider builds mean that testers and administrators must proceed deliberately. For consumers and power users, the updates offer tangible improvements that make Windows 11 feel more cohesive and capable. For IT teams, the updates provide new controls and new things to validate.
If there’s a theme across these updates, it’s that Microsoft isn’t treating legacy and modern as separate lanes anymore. Instead, the company is experimenting with bringing contemporary expectations — AI in productivity apps, consistent theming, and integrated diagnostics — to decades‑old workflows, while simultaneously providing administrators new levers to maintain control and security. That balancing act will define how smoothly these features land for the millions of Windows 11 users who rely on both old scripts and new creativity tools every day.
Source: Technobezz Microsoft Updates Windows 11 and Paint App with New Features
