Windows 11 Shared Audio Preview Streams the Same Bluetooth LE Audio to Two Devices
Microsoft has quietly added a long‑requested convenience to Windows 11: a native “Shared audio (preview)” that can stream the same Bluetooth audio feed to two separate headsets, earbuds, speakers, or hearing aids at once — and it’s arriving first for a narrow set of Copilot+ laptops as part of the Windows Insider preview.
A laptop screen shows a shared audio control panel while wireless earbuds sit nearby.Background / Overview​
Bluetooth audio on PCs has been hamstrung for years by legacy protocol choices that forced a trade‑off between high‑quality playback and microphone use. The new Windows 11 Shared audio feature builds on Bluetooth Low Energy (LE) Audio — specifically the LC3 codec, isochronous channels (ISO), and broadcast‑style primitives often referred to as Auracast — to duplicate a single, synchronized audio stream to two compatible receivers. Microsoft surfaced the capability in Windows Insider Preview Build 26220.7051 for the Dev and Beta channels and is rolling it out in a staged preview to supported Copilot+ PCs. Short practical framing:
  • What it does: sends the same audio stream from one Windows 11 PC to two Bluetooth LE Audio sinks simultaneously.
  • Where it appears in the OS: a Quick Settings tile labeled Shared audio (preview) in the taskbar Quick Settings panel.
  • Who can try it today: Windows Insiders on the Dev/Beta channel running Copilot+ compatible devices that have the required OS and driver updates.
Why this matters: a practical win for everyday scenarios​
This is the kind of small feature that changes day‑to‑day convenience rather than headline performance numbers. Native shared audio solves common, mundane problems:
  • Two people watching a movie on one laptop without a wired splitter or having to trade earbuds.
  • Students or colleagues sharing a piece of audio while collaborating locally.
  • People who rely on hearing aids listening in sync with family members using headphones.
  • Travelers wanting private audio while using the host PC’s streaming apps.
Apple and some Android vendors have offered variants of multi‑device audio sharing for years; Microsoft’s addition brings that same convenience to the PC ecosystem using the standards‑based LE Audio stack. Early coverage and the Windows Insider blog both emphasize the social and accessibility use cases as the primary intent.
How Shared audio works in Windows 11​
The user flow (what you’ll actually see)​
  • Pair and connect two Bluetooth LE Audio accessories to the PC via Settings > Bluetooth & devices.
  • Open Quick Settings from the taskbar and look for the Shared audio (preview) tile.
  • Click the tile to reveal a list of paired, connected devices that support LE Audio.
  • Select two accessories, then click Share to begin streaming the same audio to both devices.
  • Click Stop sharing to end the session.
The UI is intentionally simple: Microsoft’s goal is to hide the complexity of codecs, isochronous channels and timing synchronization behind a single tile and a couple of clicks.
The technical plumbing (brief, non‑exhaustive primer)​
  • LC3 codec: a modern, low‑complexity codec introduced for LE Audio; provides better perceived audio quality at lower bitrates compared to SBC, which helps when a host needs to feed multiple receivers without saturating the radio.
  • Isochronous Channels (ISO): timing guarantees in the LE Audio transport that keep multiple receivers playback‑aligned and reduce perceptible offset between devices.
  • Broadcast / Auracast primitives: allow a source to advertise an audio stream and support one‑to‑many scenarios; Microsoft’s Shared audio behaves like a controlled broadcast limited to two selected sinks in preview.
Because the feature relies on these protocol primitives, it is standards‑based rather than a proprietary Microsoft trick — which improves the chance of cross‑vendor interoperability so long as firmware and drivers expose LE Audio correctly.
Compatibility and current limitations​
Hardware and software gates​
  • Required OS build: Windows 11 Insider Preview Build 26220.7051 (Dev & Beta channels) or later to see the preview tile.
  • Required PC class: Copilot+ PCs only at launch (devices with NPU/AI silicon and a Copilot+ certification), with initial support limited to a short list of Surface models and a handful of Samsung Galaxy Book SKUs marked “coming soon.” Microsoft explicitly warns that the feature will be expanded to more Copilot+ PCs over time.
  • Required Bluetooth support: the host PC’s Bluetooth controller, firmware and Windows drivers must expose the LE Audio stack (including support for the LC3 codec and ISO channels). Vendor driver updates are typically delivered via OEM Windows Update channels.
  • Required accessories: both receivers must support Bluetooth LE Audio (LC3, ISO/broadcast-capable) and ideally have the latest firmware via the vendor companion app. Popular LE Audio models mentioned in preview material include several Samsung Galaxy Buds models and Sony WH‑1000XM6 examples; hearing‑aid vendors with LE updates were also cited.
Devices listed in the initial Copilot+ preview window​
Available today (preview):
  • Surface Laptop — 13.8‑inch and 15‑inch | Qualcomm Snapdragon X (Copilot+).
  • Surface Laptop for Business — 13.8 and 15‑inch | Qualcomm Snapdragon X.
  • Surface Pro — 13‑inch | Qualcomm Snapdragon X.
  • Surface Pro for Business — 13‑inch | Qualcomm Snapdragon X.
Coming soon:
  • Samsung Galaxy Book5 360 | Intel Core Ultra Series 200.
  • Samsung Galaxy Book5 Pro | Intel Core Ultra Series 200.
  • Additional Surface models and other Copilot+ SKUs as OEMs release driver updates.
What the limitations mean in practice​
  • Non‑Copilot Windows 11 PCs are unlikely to see this capability in the immediate rollout. Microsoft is intentionally gating the feature to Copilot+ hardware where partners already expose the required LE Audio stack; that reduces early‑stage fragmentation but excludes many devices at first.
  • Even on supported hardware, accessory firmware and vendor driver availability are common bottlenecks. Users frequently need to update headphones via their companion apps before Windows will recognize them as LE Audio sinks for shared playback. Community reporting from early Insiders emphasizes re‑pairing accessories after firmware updates as a frequent troubleshooting step.
A closer technical look: LC3, ISO, Auracast and why they matter​
Windows’ Shared audio is an application of three LE Audio pillars:
  • LC3 (Low Complexity Communications Codec) reduces bitrate requirements while maintaining or improving perceived audio quality. That efficiency is critical when a single radio is feeding multiple sinks; less airtime per stream reduces collisions and battery draw on accessories.
  • Isochronous Channels (ISO) are the timing transport that preserve synchronization across receivers. For two headsets to hear the same movie in sync, ISO provides the low‑latency, time‑aligned delivery guarantees needed to avoid distracting echo or lag.
  • Auracast / Broadcast primitives enable one source to let multiple listeners subscribe to a stream without full point‑to‑point pairing. Microsoft’s preview limits the UX to two receivers, but the underlying tech is the same as Auracast and can support larger broadcast scenarios in other implementations.
Together, these primitives move shared listening from a kludgy workaround into a native OS capability — provided the ecosystem of Bluetooth silicon vendors, OEMs and accessory makers all update firmware and drivers appropriately.
Strengths and immediate benefits​
  • Native convenience: replaces cable splitters and fragile software routing tools with a single OS control surfaced in Quick Settings.
  • Standards‑based interoperability: built on LE Audio (LC3/ISO/Auracast primitives) which improves the chance of cross‑vendor compatibility over proprietary pair‑and‑duck workarounds.
  • Accessibility gains: direct streaming to hearing aids and assistive devices is explicitly called out by Microsoft as a use case and is one of the most meaningful benefits of LE Audio’s standardization.
  • Potential battery and quality gains: LC3’s efficiency and LE Audio’s transport improvements can preserve better perceived audio quality at lower bitrates and extend accessory battery life compared with legacy SBC/A2DP solutions.
Risks, caveats and practical concerns​
  • Narrow early availability: gating to Copilot+ PCs leaves many Windows 11 users excluded in the short term; adoption speed will depend on OEM driver rollouts and accessory firmware updates. Microsoft’s staged rollout is prudent, but it’s slow for broad impact.
  • Interoperability hiccups: LE Audio is a standard, but real‑world compatibility requires three pieces to be correct — the PC radio/firmware, OEM drivers, and accessory firmware. If any link is missing, the feature will not work as expected or may fall back to classic Bluetooth behavior. Community threads and early reports show device‑specific quirks during preview testing.
  • Limited to two receivers in preview: Microsoft currently caps the preview to two sinks. That’s sufficient for most “share with one friend” scenarios, but it’s not a full Auracast deployment for public venues yet.
  • Potential latency/quality edge cases: even with ISO transport, edge devices can show sync drift or momentary stutter if driver or firmware implementations are immature. Insiders are urged to report glitches through Feedback Hub so Microsoft and OEMs can iterate.
  • Enterprise and privacy considerations: organizations that manage laptops should consider whether and how shared audio may interact with device policies, digital rights management (DRM) playback scenarios, or meeting controls — especially if allowed in public spaces where audio broadcasts might be inappropriate. These operational controls may be necessary in some deployments.
How to try Shared audio today (step‑by‑step)​
  • Confirm your PC is a Copilot+ device listed as supported in Microsoft’s preview notes and that it’s enrolled in the Windows Insider Dev or Beta channel.
  • Install Windows Update until Build 26220.7051 (or later) is present. Use Settings > Windows Update and enable the Insider preview channel if required.
  • Update OEM Bluetooth and audio drivers when offered through Windows Update, or install the vendor‑supplied drivers recommended by your PC manufacturer.
  • Update accessory firmware using the manufacturer’s companion app; many vendors only expose LE Audio functionality after app‑delivered firmware updates. If your accessory doesn’t appear under Shared audio, remove it from the PC and re‑pair after the firmware update.
  • Pair and connect two LE Audio devices in Settings > Bluetooth & devices.
  • Open Quick Settings (taskbar), click the Shared audio (preview) tile, select two devices from the list and click Share. Use Stop sharing to stop.
Practical tip: keep a wired fallback (headphone splitter) for critical sessions until the driver/firmware ecosystem matures and the preview has proven itself on your device pairings.
What to watch next and how the rollout might expand​
  • OEM driver updates: the pace at which additional Copilot+ devices (and eventually non‑Copilot devices) gain support depends heavily on OEMs shipping Bluetooth and audio driver updates that expose LE Audio primitives to Windows.
  • Accessory firmware updates: larger accessory vendor rollouts — especially from mainstream headphone makers — will determine how many consumers can actually use the feature without buying new hardware.
  • Potential expansion beyond Copilot+: Microsoft’s initial gating to Copilot+ hardware is conservative. The company has signaled broader rollout once driver and partner readiness improves; whether that expands to legacy Windows 11 PCs remains an open product decision.
  • UX improvements: expect Microsoft to iterate the experience (discoverability, pairing UX, encryption and access controls) based on Insider telemetry and partner feedback before a general release.
Final assessment — should users care?​
For eligible users — Copilot+ Insiders with LE Audio accessories — Shared audio (preview) is a welcome and practical feature that solves a real‑world annoyance. It’s standards‑based, reasonably straightforward to use, and delivers immediate benefits for shared media and accessibility scenarios. The technical underpinnings (LC3, ISO, Auracast‑style broadcast) are solid, and Microsoft’s staged approach reduces the likelihood of a chaotic, fragmented early experience. For the broader Windows user base, the feature matters as a signal: LE Audio is arriving on the PC platform in a concrete, consumer‑facing way. But the timeline for widespread availability depends on OEMs and accessory vendors updating firmware and drivers. In short: valuable now for a narrow set of users, important for the broader ecosystem as adoption grows.
Quick reference: checklist before trying Shared audio​
  • Enroll in Windows Insider Dev/Beta channel (if you want the preview).
  • Confirm your PC is a Copilot+ model on Microsoft’s supported list.
  • Update Windows to Build 26220.7051 or later.
  • Install OEM Bluetooth/audio driver updates via Windows Update.
  • Update accessory firmware via vendor companion apps and re‑pair devices if necessary.
  • Keep a wired fallback for mission‑critical needs.
Microsoft’s Shared audio (preview) is a pragmatic, standards‑driven step that brings PC audio sharing into parity with features mobile users have had for years. The initial rollout is intentionally conservative: it prioritizes reliability and interoperability on Copilot+ hardware while giving Microsoft and partners controlled telemetry to refine behavior. The feature’s success will hinge on vendor firmware, driver quality, and the pace at which OEMs broaden support — but once those pieces align, Windows users will gain a simple, friction‑free way to share audio without cables, splitters, or awkward earbuds‑sharing.
Source: TechRadar https://www.techradar.com/computing...-sharing-feature-for-some-heres-how-it-works/
Microsoft is quietly testing a native Windows 11 feature that can stream the same Bluetooth audio to two headsets, earbuds, speakers or hearing aids at once — surfaced to Windows Insiders as a Quick Settings tile called Shared audio (preview) and built on the new Bluetooth LE Audio stack that includes the LC3 codec and Auracast-style broadcast primitives.
Blue-toned tech setup with a monitor, wireless headphones, and earbuds emitting Bluetooth audio waves.Background / Overview​
Bluetooth audio on PCs has long been hamstrung by legacy design choices: high-fidelity one-way playback via A2DP or poor-quality two-way audio via HFP/HSP, forcing trade-offs whenever microphone input was required. Bluetooth Low Energy (LE) Audio — the modern audio architecture standardized by the Bluetooth SIG — replaces important parts of that old model with more efficient codecs (LC3), support for isochronous transport (ISO) and broadcast-style delivery commonly branded as Auracast. Those technical changes make reliable, synchronized multi-receiver audio feasible on mobile devices and now, for the first time in a visible way, on Windows desktops and laptops.
Microsoft’s preview exposes a straightforward user flow: pair two LE Audio-capable accessories, open Quick Settings, choose the Shared audio (preview) tile, pick the two outputs and press Share. The system opens synchronized LE Audio streams to both sinks and streams the same audio content to each device concurrently. Microsoft is deliberately staging the rollout: the capability first appeared in Windows 11 Insider Preview Build 26220.7051 and is limited to a defined set of Copilot+ PCs while drivers and firmware mature.
What Microsoft shipped — the essentials​
How the preview is surfaced​
  • The feature appears as Shared audio (preview) in Quick Settings on updated Insider builds.
  • Workflow is intentionally simple: pair two LE-capable accessories → open Quick Settings → select Shared audio → choose two devices → press Share → Stop sharing ends the session.
Windows build and distribution​
  • Previewed in Windows 11 Insider Preview Build 26220.7051 (Dev and Beta channels).
  • Microsoft is rolling the feature out gradually, gating availability to Copilot+ devices that meet Bluetooth controller, driver and firmware requirements.
Initial device and accessory examples​
  • Microsoft’s early availability notes and independent reporting call out specific Copilot+ Surface SKUs (Surface Laptop 13.8" and 15", Surface Pro 13") among the first hosts to receive the preview. These are representative examples rather than an exhaustive supported list.
  • Vendors and early coverage name accessories that already support LE Audio or have received LE Audio firmware updates — examples include recent Galaxy Buds models and the Sony WH‑1000XM6 family — but accessory compatibility depends on the vendor’s firmware and companion apps.
LE Audio, LC3 and Auracast — a short technical primer​
Understanding Shared audio requires a quick look under the hood at the LE Audio primitives Microsoft relies on.
LC3 codec​
The LC3 codec (Low Complexity Communications Codec) is designed to provide equal or better perceived audio quality than legacy SBC at far lower bitrates. That efficiency reduces radio airtime and makes it feasible for a single host to feed multiple receivers without saturating the Bluetooth channel or dramatically draining batteries on accessories. LC3 supports high-quality sampling rates up to 48 kHz, providing the fidelity expected on desktop media scenarios.
Isochronous Channels (ISO)​
Isochronous Channels (ISO) are the LE transport primitive that introduces timing guarantees needed to keep multiple receivers synchronized. Without ISO, listeners would hear significant drift or offset. ISO lets the host coordinate packet timing across recipients so playback remains tightly aligned.
Auracast / Broadcast primitives​
Auracast is the consumer-facing name for LE Audio’s broadcast model: a transmitter advertises an audio stream and many receivers can join. Microsoft’s preview uses the same underlying multi-recipient primitives but initially exposes a controlled, paired two-device experience rather than an open public broadcast. This staged approach reduces complexity while the ecosystem converges on firmware, drivers and user UX.
Where it works now — compatibility and gating​
Shared audio is not a pure software-only toggle; it depends on coordination across multiple layers:
  • Windows 11 build: The PC must be running the Insider build that includes the Shared audio preview tile.
  • OEM Bluetooth & audio drivers: The PC’s Bluetooth controller and audio drivers must expose the LE Audio stack; these drivers are delivered via OEM channels or Windows Update.
  • Accessory firmware: Each headphone, earbud, speaker or hearing aid must support Bluetooth LE Audio — either natively or via a vendor firmware update — so it can receive LC3-encoded streams and join isochronous sessions.
  • Hardware gating: Microsoft has limited the initial preview to Copilot+ PCs where Qualcomm Snapdragon X-series platforms and compatible Bluetooth radios already expose the necessary primitives; other OEM Copilot+ machines are listed as coming soon in Microsoft’s staged rollout.
Practical implication: many Windows 11 users will not see Shared audio immediately. Expect the Quick Settings tile to appear only after both OS and vendor drivers/firmware are updated and the PC is on Microsoft’s preview compatibility list.
How to enable Shared audio (practical steps)​
If your device appears in the preview compatibility list and you have LE Audio accessories, the steps are straightforward.
  • Enroll the PC in the Windows Insider Program (Dev or Beta channel) and install Windows 11 Insider Preview Build 26220.7051 or later.
  • Update your PC’s Bluetooth and audio drivers via Windows Update or the OEM support site.
  • Update accessory firmware using the vendor’s companion app. If the accessory manufacturer has not published LE Audio firmware, the device will not participate.
  • Pair and connect both Bluetooth LE Audio devices in Settings > Bluetooth & devices.
  • Open Quick Settings (taskbar), locate the Shared audio (preview) tile and tap it.
  • Select the two connected devices you want to stream to, then press Share. Use Stop sharing to end the session.
Key prerequisites to check before trying:
  • Both accessories must advertise and support LE Audio (LC3, ISO).
  • Each device should be paired and shown in Settings > Bluetooth & devices.
  • PC drivers and accessory firmware must be current; re-pairing is often required after updates.
Real-world use cases — why this matters​
Shared audio on Windows 11 unlocks practical scenarios that previously needed physical splitters, third-party dongles or kludgy software routing.
  • Shared viewing on the go: Two people can watch a movie on a laptop on a flight without disturbing neighbors.
  • Travel and commuting: Friends or family can listen to the same track privately while using their own headsets.
  • Education and study groups: Students can share lecture audio or language practice sessions directly from one PC.
  • Accessibility: Broadcasting the same audio to hearing aids and headphones simultaneously improves inclusion in venues where an assistive feed is needed.
  • Demo and comparison listening: Producers or audio engineers can let two listeners evaluate mixes in sync without cable swaps.
Beyond simple convenience, LE Audio’s efficiency also offers meaningful battery benefits for accessories because LC3 typically achieves comparable perceived quality at lower bitrates than older codecs. That efficiency matters when one host supports multiple concurrent connections.
Critical analysis — strengths and practical risks​
Strengths​
  • Standards-driven approach: Microsoft built Shared audio on LE Audio primitives (LC3, ISO, broadcast) rather than a proprietary hack. That increases the chance of cross-vendor interoperability as the ecosystem updates.
  • Simplicity for users: Surfacing the capability as a Quick Settings tile hides complex transport details, making shared listening accessible to non-technical users.
  • Accessibility upside: Direct streaming to LE Audio hearing aids aligns Windows with assistive-listening goals and could simplify hearing-aid workflows in public spaces.
  • Power and quality benefits: LC3’s efficiency and ISO’s synchronization enable multi-recipient audio with lower airtime and acceptable fidelity.
Risks and limitations​
  • Ecosystem dependency: Reliable multi-device audio requires firmware and driver updates across PC radios and accessory vendors. If any vendor delays updates, users will face compatibility gaps. Microsoft’s preview gating reflects this reality.
  • Limited to two devices (preview): The initial preview caps sessions to two receivers. This controlled scope is sensible for testing but is not a full Auracast-style one-to-many broadcast yet.
  • Interoperability quirks: Mixed-brand pairings frequently reveal timing, codec fallback and transport behavior differences. Expect occasional stutter, dropped packets, or subtle desynchronization with certain accessory combinations.
  • Driver and firmware complexity: Users must update both system drivers and accessory firmware — sometimes via vendor apps — which raises barriers for casual users and managed IT environments.
  • Latency considerations for professional use: While LE Audio improves synchronization, any wireless multi-sink solution will still carry more latency than wired monitoring; this may make Shared audio unsuitable for low-latency professional workflows like critical audio monitoring or live performance.
Flagged claim: some early reports list specific Surface models and Qualcomm Snapdragon X-based SKUs as supported "available now." Those device lists are based on Microsoft’s staged preview notes and third-party reporting; treat them as illustrative rather than a guaranteed compatibility roster for every SKU. Confirm device support on your PC by checking the Quick Settings presence and OEM driver releases before assuming availability.
Troubleshooting and testing guidance​
If you’re an Insider tester or IT professional evaluating the preview, these practical tips will help isolate problems and produce actionable feedback.
  • Update everything first:
  • Install the required Insider build.
  • Update Bluetooth and audio drivers via Windows Update or OEM support pages.
  • Use accessory vendor apps to push the latest firmware to earbuds/headphones.
  • Re-pair devices after firmware/drivers change:
  • Remove and re-pair accessories if they don’t appear in the Shared audio picker. Many early testers report re-pairing resolves visibility and capability issues.
  • Test with same-brand devices when possible:
  • Early cross-vendor inconsistencies mean testing with two devices from the same vendor often yields cleaner results. Note that this is not a guarantee; driver/firmware versions still matter.
  • Monitor battery and heat:
  • Running dual LE Audio streams can increase radio activity on the host and the accessories — track battery and thermal behavior during extended sessions.
  • Collect logs and send feedback:
  • Use Feedback Hub to report reproducible issues and include driver/firmware versions, accessory models and repro steps. Microsoft’s staged preview depends on Insiders’ telemetry and feedback to expand support reliably.
Governance, security and enterprise considerations​
From an IT governance standpoint, Shared audio is a low-risk consumer convenience but carries a few considerations for managed environments:
  • Policy and DLP: Shared audio duplicates output to paired personal accessories; organizations with strict content-sharing policies should review how LE Audio broadcast primitives interact with data-loss prevention policies and meeting controls.
  • Device management: Firmware and driver coordination across many accessory models complicates large-scale rollouts; IT teams should pilot on a limited set of vendor-tested devices before approving broad adoption.
  • Hearing-assistance benefits: Deploying Shared audio in public spaces or training rooms could improve accessibility, but facilities managers should work with hearing-aid vendors to confirm compatibility and privacy protocols when broadcasting audio in public areas.
What to expect next — roadmap and ecosystem outlook​
Shared audio’s public preview is a credible signal that LE Audio is finally reaching the PC ecosystem in a practical form. The immediate next steps likely include:
  • Expanded device support: Microsoft will widen availability beyond the initial Copilot+ list as more OEM drivers and Bluetooth firmware roll out.
  • Accessory firmware updates: As vendors push LE Audio updates to more models, the installed base of compatible headsets and hearing aids will grow, making the feature usable for more consumers.
  • Broader Auracast capabilities: Microsoft may extend the UX from a curated two-device sharing experience to more open broadcast modes for venues and multi-user scenarios — but that requires deeper UX and privacy controls.
  • Driver and stack maturation: Expect improvements in inter-vendor synchronization, fallback behavior and power management as the Windows LE Audio stack and OEM drivers iterate. Early tester feedback will shape these optimizations.
The longer-term impact is clear: if LE Audio adoption becomes widespread across PC radios and consumer accessories, multi-sink audio will stop being a novelty and become a built-in convenience for shared listening, assistive listening and small-group media workflows.
Practical verdict — who should try it today​
  • Try it now if:
  • You own a Copilot+ PC listed in Microsoft’s preview compatibility notes and you have two LE Audio-capable accessories (or vendor-updated models).
  • You are comfortable with Insider builds and willing to update drivers/firmware and provide feedback through Feedback Hub.
  • Wait if:
  • Your PC or accessories are older and lack LE Audio support; expect better compatibility as vendors publish firmware updates.
  • You need deterministic, ultra-low-latency audio for professional monitoring or live performance — wired options remain the gold standard for those use cases.
Windows 11’s Shared audio (preview) is a pragmatic and standards-driven first step that brings an increasingly common smartphone convenience to the PC: streaming the same Bluetooth audio to two LE Audio receivers at once. By building on LC3, isochronous channels and broadcast primitives, Microsoft can deliver synchronized multi-recipient playback with improved efficiency and better hearing-aid support than older Bluetooth stacks allowed. The staged rollout — limited to Copilot+ PCs and gated by driver and firmware readiness — reflects the practical dependencies of bringing LE Audio to a heterogeneous PC ecosystem. Early testers should expect a mostly polished user experience but also device-specific quirks that will be resolved as vendors ship updates and Microsoft refines the Windows audio plumbing. In short, Shared audio is not an overnight revolution, but it is a notable and useful sign that multi-device, Auracast-capable audio is moving from concept into everyday Windows reality.
Source: RouteNote Windows 11 tests Bluetooth Audio sharing: Stream sound to multiple devices at once on PC - RouteNote Blog
